Go to Post note to self: do not use robot to retrieve cars from water. - Greg Marra [more]
Unread 15-02-2007, 22:12
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: const array - 'auto' compile error ?
I got the same error, I just removed the rom classification to make it work.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 15-02-2007, 22:43
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Wouldn't this make it be stored in RAM, not ROM? I think the purpose of putting it in ROM is because there isn't enough room in RAM....
Just speculating, haven't actually tried it.
Jacob
Unread 15-02-2007, 23:19
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
Removing the word rom, and with an array of length 256 (unsigned char) I get this error:
stack frame too large
So I don't think that is creating the array in program space? Smaller arrays do compile.
Unread 16-02-2007, 01:26
AKA: Jacob Komar
mmmm....
I think you have a total of 254 chars, including the ones you use in your program. I just seem to remember this number. I could be completely off the mark.
Jacob
Unread 16-02-2007, 13:47
Electrical Engineer
Rookie Year: 1995
This will not work:
 rom const unsigned char L3[] = {000,001};
This will work:
 rom const unsigned char L3[2] = {000,001};
You have to tell the compiler the size of the array in ROM data space.
Mike
Mike Betts
As easy as 355/113...
Unread 16-02-2007, 14:19
Originally Posted by Mike Betts View Post
This will work:
Mike
I changed my code:
rom const unsigned char LUT4[256] = {000,003,006,009,012,014,017,020,023,025,028,030,033,035,038,040,042,044,047,049,051,053,055,057,059,061,063,065,067,069,070,072,074,076,077,079,080,082,083,085,086,088,089,090,092,093,094,095,096,098,099,100,101,102,103,104,105,106,107,108,108,109,110,111,111,112,113,114,114,115,116,116,117,117,118,118,119,119,120,120,121,121,121,122,122,122,123,123,123,124,124,124,124,125,125,125,125,125,125,126,126,126,126,126,126,126,126,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,128,128,128,128,128,128,128,128,129,129,129,129,129,129,130,130,130,130,131,131,131,132,132,132,133,133,133,134,134,135,135,136,136,137,137,138,138,139,140,140,141,142,143,143,144,145,146,146,147,148,149,150,151,152,153,154,155,156,158,159,160,161,162,164,165,166,168,169,171,172,174,175,177,178,180,182,184,185,187,189,191,193,195,197,199,201,203,205,207,210,212,214,216,219,221,224,226,229,231,234,237,240,242,245,248,251,255};
Still didn't work for me, but maybe I don't have the code in the right part of the project. Where should the code go? Seems like it can't be in a User Function, and there is no way to enter it in Main...Globals and there is no way to add User Code to Main. I'm sure I could get it to work in MPLAb, but Easyc Pro is fighting me.
Unread 16-02-2007, 18:19
Electrical Engineer
Rookie Year: 1995
I did not realize you are using easyC. I am not sure how to work in that environment.
In MPLAB, it would go before the first function call in the file.
Mike Betts
Unread 17-02-2007, 01:22
AKA: Brad
#0190 ( Gompei and the Herd)
One way that works with easyC Pro to use the new C source file feature that was just added this year.
Create a source file (go into the project tab, right click "Source Files" and create a file). In there put the definition of the array with the initialization:
Then edit the file UserInclude.h and insert an extern declaration for the array like this:
extern rom const unsigned char L3[];
Now you can use references to the L3 array in assignment statements or other expressions throughout your block-based easyC program. The only problem is that the array will not show up in the list of variables when you are creating expressions.
Brad Miller
Robotics Resource Center
Unread 17-02-2007, 01:36
Thanks Brad. That did the trick.
Array Syntax Error Andrew Blair Programming 7 05-02-2006 14:11
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
compile error Chuck Merja Programming 3 17-02-2005 15:02
InterruptVectorLow error when we compile Redneck Programming 5 02-02-2005 22:57
Compile error blindguyinanorg Programming 4 12-02-2004 19:49
