Go to Post That's one of the saddest stories I've ever heard. When your green isn't neon enough, you are in big trouble in FIRST. - JaneYoung [more]
Unread 15-02-2007, 14:01
Bharat Nain's Avatar
Camera tracking other lights
The camera always successfully tracks the green light which is on a fully charged battery. However, we have sunroofs on the top of our gym and the camera detects the light from there also when the sun is right above. I have tried changing the saturation levels but that doesn't help. It seems like the light from the sunroof has more green in it than the green light itself. Any ideas?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 15-02-2007, 15:00
Re: Camera tracking other lights
Sunlight is powerful stuff, and you probably can't overcome the issue with programming. About the only thing I can suggest is a sun visor or a green filter on the lens to keep the camera from being overwhelmed by the broad-spectrum light from overhead.
Unread 15-02-2007, 15:15
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Do the skylights show up when you look at the Tracking Frame with the LabView GUI? If so, is it possible to limit the camera's field of view (with a mask or tilt limit) so it doesn't see them?
Things I've seen happen with bright interfering light sources are:
- If the interfering light is very bright and near the line of sight between the camera and the target light, or it reflects off the face of the target light, it can swamp the target out, even if it doesn't contain the target color.
- If the interfering light is broad-spectrum white light (which sunlight is), it will contain the green we're looking for and, if it is bright enough, the camera may see it as a valid target. It has to be really bright, though.
I've got a camera looking out the window at bright sunny (& snow covered) scene right now. Using the 2006 Target.cfg config, with the Noise Filter set to 1, it isn't picking up anything at all. However, if I set the Noise Filter to 0, the camera picks up the light off reflective surfaces, like a shiny car parked outside. Reducing the Saturation Control to 120 (from 128) eliminated them.
Pete Kieselbach
Unread 15-02-2007, 15:29
I think our best bet is to get up over the roof and cover those openings. The light is right above our rack so there really is no way to block it out. We played with the camera settings quite a bit and nothing really helped. I thought about a visor or filter, but I am not sure how to fix it on the camera. It might be more trouble than just letting the camera see the light for a couple hours. Thanks for the suggestions.
-= Bharat Nain =-
Unread 15-02-2007, 17:22
whlspacedude's Avatar
whlspacedude whlspacedude is offline
AKA: Will
FRC #1529 (Cyber Cards)
whlspacedude is just really nicewhlspacedude is just really nicewhlspacedude is just really nicewhlspacedude is just really nice
Send a message via AIM to whlspacedude Send a message via MSN to whlspacedude Send a message via Yahoo to whlspacedude
We are having that problem with regular lights the camera tracks all of the lights within its viewing area including the green lights
Some people are like slinkies they are only good for 1 thing... pushing them down flights of stairs
1529 mph = 4 109 952 furlongs per fortnight
Unread 15-02-2007, 18:03
If its just the lights in a shop, then you can adjust the saturation and noise filter and most likely it will be fixed. Look at petek's post.
-= Bharat Nain =-
Unread 15-02-2007, 22:21
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Are there any severe performance side effects with with a noise filter of 1 or 2? If no, why does the camera code change them from the default of 2 and set them to 0?
Thanks in advance,
Robinson
Unread 19-02-2007, 13:30
Teammax's Avatar
Teammax Teammax is offline
30 Members 6 Weeks 1 Dream
AKA: Rob Cormier
FRC #1071 (Team MAX)
Teammax is just really niceTeammax is just really niceTeammax is just really niceTeammax is just really nice
I think we are having the same type of problem. When we use our camera at our school it works great and we can score in autonomous. When we went to the Winter War Zone Scrimmage we had many tracking issues.
How do we know what our noise filter is set to and could someone tell where to look in the code to change it. Please.
Unread 19-02-2007, 13:40
If you're using the "Bells & Whistles" camera code, you can change it from the built-in menu facility by connecting a terminal to the robot's program port and typing "c" to access the camera menu.
The IFI Loader program contains a built-in terminal program which activates automatically after downloading a program to the robot. You can also activate it manually from the Option menu.
Unread 19-02-2007, 13:54
Teammax's Avatar
AKA: Rob Cormier
Thanks I think I have found it
camera tracking geekofband007 Programming 15 15-02-2007 23:50
Camera tracking between two lights Ankush Dhar Programming 2 12-02-2007 23:44
Tracking two lights Render Programming 5 29-01-2007 18:14
Camera finds overhead lights not green light theycallhimtom Programming 4 20-01-2007 17:37
No lights on camera Bob22341 Programming 4 08-02-2006 13:27
