Go to Post Good thing you skipped this year. You don't need exhaustion to sleep through Recycle Rush. - Gregor [more]
Unread 16-02-2007, 00:15
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: Wiring an Elevator
In 2005 we dealt with a similar issue. We had a lot of luck using the "coiled" method (but with a minor twist). We were worried about weakening the wire by heating and coiling it, so instead we wrapped some extra pneumatic tubing around a piece of 2" PVC, and used a heatgun to make it coil (simply heat the coil evenly for perhaps 10 minutes, then let it cool and remove it from the pvc) . We then simply ziptied our wire runs onto the PVC with some light-strength, tiny zipties. Worked like a charm; no problems with connections breaking, and it looks pretty okay.
//Dillon Compton
Team 1394
www.metalmoose.com
pic: Israel regional crates elevator David55 Regional Competitions 2 28-03-2006 22:29
Elevator robots why didn't you.. Collmandoman General Forum 19 02-04-2005 17:17
Elevator Trouble: The Marta Ben Lauer Championship Event 26 29-04-2004 20:06
1418's Elevator Party? phrontist Chit-Chat 0 26-04-2004 03:03
Space Elevator Ian W. Chit-Chat 28 31-07-2002 14:04
