Go to Post ...there's no easier way to get something changed than to have it happen on FIRST's biggest stage. - Billfred [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-02-2007, 11:23
Oumonkey's Avatar
Oumonkey Oumonkey is offline
Master of the If statement
AKA: Josh Tyus
FRC #1555 (Pulse)
Oumonkey has a spectacular aura aboutOumonkey has a spectacular aura about
Back-up Battery question
Hello,
I've been told that new yellow back-up battery is all we are allowed to use for the regionals. I want to know if that is true, but I have been searching for a place to buy them and I can't seem to find anyplace. Ifirobotics only has the blue ones, and I am unsure which kind we are allowed to use. I went throught the manuals and didn't see anything. I looked though CD and I didn't find anything either. So I guess my question is are we allowed to use the blue back-up battery? And if not where can I purchase the yellow ones. I'm sorry if this is somewhere obvious, but I just can't seem to find any information.
Thanks
Josh
Unread 10-02-2007, 12:16
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: Back-up Battery question
According to rule R73:
<R73> The 7.2V Robot Control backup battery must be connected to the Robot Controller as described in the Robot Controller manual. The 7.2v battery should be charged to at least 7.0v before entering a match. As a replacement for the FIRST supplied battery, any other commercially available 7.2V NiCad battery pack may be used.
So you can use any 7.2V NiCad battery including the blue one available for purchase from IFI.
Unread 10-02-2007, 12:17
Electrical Engineer
Rookie Year: 1995
You received a blue backup battery in your KOP. The intended purpose is so that you can use it on your robot.
Also:
Mike Betts
As easy as 355/113...
Unread 10-02-2007, 12:23
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Some teams (such as mine) received a yellow backup battery in their kits. I believe this is what led to the confusion.
Unread 10-02-2007, 12:37
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
But!!!! you must use the supplied charger in the Kit of Parts! None of you guys included that, so I thought I should. And yes, I do recommend getting a larger capacity battery, and using it the whole day, and charging it overnight at competition.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 11-02-2007, 02:37
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Now that I do not believe is true. It is completely true that you must use the supplied charger in the kit of parts for the main 12v battery, but you do not have to use the supplied charger for the backup battery so long as your backup battery charger is still safe. The reason being that the backup battery you might have may not have a compatible adaptor for the [supplied] charger, and it would be extremely silly to require you to create an adaptor to fit just for charging.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 11-02-2007, 06:48
Electrical Engineer
Rookie Year: 1995
Originally Posted by Danny Diaz View Post
...but you do not have to use the supplied charger for the backup battery so long as your backup battery charger is still safe...
Danny,
Your point is well taken but is not supported by exact interpretation of the rules.
<R56> The 7.2v backup battery may be charged on or off the ROBOT. When off the ROBOT, the battery is to be charged with the provided 7.2V backup battery charger.
This is one of the FIRST rules which is largely non-enforceable. I also agree that, from an engineering standpoint, there are many better solutions than the provided charger. This is particularly true of "smart" chargers which monitor the state of charge of the battery (they utilize an embedded microcontroller and look for the minus dv/dt "bump") and adjust the charging current accordingly.
As it stands right now, few inspectors will walk the pits looking at your NiCad chargers. However, if pressed, they would have little choice than to quote <R56>.
I invite you to air your concerns on the FIRST Q&A. Only by airing these concerns to FIRST will we get the rules changed.
That's JMHO...
Mike
Mike Betts
Unread 12-02-2007, 13:27
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Danny,
Your point is well taken but is not supported by exact interpretation of the rules ... I invite you to air your concerns on the FIRST Q&A. Only by airing these concerns to FIRST will we get the rules changed.
Concern aired. Hopefully I'll get an answer.
-Danny
Danny Diaz
Unread 12-02-2007, 13:35
Danny,
Mike gave you the answer, I am afraid. The robot rules are very specific. I prefer to inspect robots in their pit as do many other inspectors. This prevents a pile up at the weighin and size stations and it gives us a chance to make students feel a little more comfortable. I like to check out the pit and see chargers, extra compressors and safety violations that may have been missed by the safety people. It's all part of the full service.
Unread 13-02-2007, 01:49
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Yeah, I understand why the rule is there, but now I have to run out and find one of those funky connectors for the charger so I can charge our COTS NiCad battery as well as the provided NiCad battery. The Q&A gave a definitive answer for me - after reading Mike's response I knew what the answer would be, but I had to ask anyway.
Thanks!
-Danny
Danny Diaz
Unread 13-02-2007, 07:20
Billfred's Avatar
Billfred Billfred is offline
Now that I do not believe is true. It is completely true that you must use the supplied charger in the kit of parts for the main 12v battery (snip)
Not quite, but close. (Emphasis in rule my own.)
<R54> The ES17-12 can only be charged between matches by a 6-ampere rated automatic battery
charger. When recharging the Kit Of Parts batteries, either the charger provided by FIRST
or an automatic charger with an equivalent charging current rating may be used.
Unread 16-02-2007, 00:28
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Just to clarify, not only are you limited to the 2007 charger for this year's back-up battery, you're limited to that charger for ALL your back-up batteries you use this year.
Yes, battery chargers from prior years would be illegal for charging the 2007 back-up battery.
Yes, the back-up battery (either the one supplied, or a permitted COTS back-up battery) must be charged with ONLY the 2007 charger or IFI-defined charger circuit, as specified in Rule <R56>.
http://forums.usfirst.org/showthread.php?t=4853
Make sure to charge your back-ups to full before the competition!
Unread 16-02-2007, 01:15
AKA: Dr. Brooks
no team (WRRF)
You only need two backup batteries. One in the robot, and one on the charger. If you change the backup battery when you change the main battery, and keep the swapped out backup battery on the charger, you will never fall behind on the charge of the backup battery. Don't leave the backup battery on the supplied KOP charger overnight. It will overheat it.
It is useful to use the 15 amp power pole connector on the backup battery. By using this connector on the battery, the robot, and on the charger, you will avoid problems with intermittent connections.
Eugene
Unread 16-02-2007, 08:09
QI'yaH!
For those of you who don't speak Klingon, that's an expression of dismay. To put it mildly. The 2007 charger doesn't indicate when the battery is fully charged, nor does it stop charging before the battery is overcharged. That settles it -- we're using the onboard charger. We'll also be pulling the breaker supplying it when the robot is not in use.
Unread 16-02-2007, 11:41
I asked a question about the backup battery charger on the Q/A a few days ago. I pointed out that an overcharged battery is a safety hazard.
battery question hiimcristhian General Forum 6 09-02-2007 11:38
Battery question CraigHickman Electrical 9 23-10-2006 21:55
Back-up battery charging circuit from IFI Don Wright Electrical 19 02-05-2006 20:41
Back up battery Jeremy General Forum 3 25-02-2004 09:56
Looking for Back up Battery? PMGRACER Kit & Additional Hardware 11 16-01-2004 12:15
