Go to Post please remember that the children we are trying to positively influence do read these forums. - Amanda Morrison [more]
Unread 16-02-2007, 01:29
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: pic: Team 195 driving base 2007
Originally Posted by nuggetsyl View Post
Y lower the middle wheel. Makes no sence.
Alright, I am going to use your team as an example. I can only assume and guess. I know you guys don't lower your middle wheels. Why? I have never been able to get a straight answer from anyone. You guys play around with your tread patterns a lot.
On the other hand, when you do a 6wd and don't lower your middle wheel, the robot is trying to turn on 6 different points. Depending on the friction you create with the wheel/tread you are using, it is very hard to turn unless you lower your middle wheel. While lowering the middle wheel, lots of team work on their CG. If the CG is low and the weight is distributed properly throughout the robot, while turning, the robot turns on 2 (middle) or 4 wheels (using only 4 different points to turn), creating less friction. At the same time, there are always 4 wheels touching the ground. I know wedgetop compresses, so if the weight is distributed properly, you get all 6 wheels touching the ground while going straight or back even if you lower your wheel. It also depends on the team how much they lower their middle wheels. I have seen teams do 1/16, 1/8, 3/16, 1/4, even 3/8 and lot of teams have been successful doing it too.
I sure would like to know how does a team turn without lowering their middle wheels. If there is anyone out there with a proper answer with reasonings behind it, please post.
Now back to topic...
As always, 195's chassis looks awesome. I am digging those wheels. Can't wait to see you guys in person. Let's not burn a victor out right before the final match this time. =)
pic: Team 195 Wheel jjdebner Robot Showcase 7 12-02-2007 19:11
pic: Team 195 base jjdebner Extra Discussion 5 06-02-2007 22:39
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: Team 195 Teaser #3 Sscamatt Extra Discussion 19 08-02-2006 01:13
pic: Team 195 hanging CD47-Bot Robot Showcase 12 02-03-2004 22:39
