Go to Post I'm all for an aggressive game, but lets not crack each others lexan. - Molten [more]
Unread 16-02-2007, 09:08
coolguybigt's Avatar
coolguybigt coolguybigt is offline
engineer rock (software is fun)
AKA: T
FRC #2043 (Robo Squad)
coolguybigt will become famous soon enoughcoolguybigt will become famous soon enough
Send a message via AIM to coolguybigt Send a message via MSN to coolguybigt
Re: need help with our default code
thank for helping
never give up,keep on going(thing will get better).
if you need help just ask? poeple are help to help. thank you
Unread 16-02-2007, 09:22
AKA: T
the code that you guy give me did not help
the problem is that when we move our joystick
the 2 motor go different way
please help
p.s how do you switch the leads on the speed controller
Unread 16-02-2007, 09:43
1. Remove the wires going from the Victor speed controller to the motor.
2. Swap the red and black wires.
3. Reattach the wires to the Victor speed controller.
This will reverse the direction that the motor runs. That's what you want, right?
Unread 16-02-2007, 09:45
AKA: T
if i change the wire
will it burn out the victor?
Unread 16-02-2007, 09:51
If the Victor is working with the output connected the way it is now, it should still work after the output wires are swapped.
(Please don't ask the same question in both the public forum and a private message at the same time.)
Unread 16-02-2007, 12:29
AKA: T
i am srry
i am new to this
Need help with our deadspace. sacr3denigma Programming 2 26-01-2006 18:09
Need help programming our swerve with feedback? activemx Programming 25 13-04-2004 07:29
Need help with my code jaywion Programming 9 20-03-2004 11:32
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
We need help with our website LBK Rules Website Design/Showcase 18 19-01-2003 17:46
