Go to Post At the Chesapeake Regional, we will be weighing any team that brings in a kitchen sink (or other major appliances) or an extra robot... - RoboMom [more]
Unread 16-02-2007, 14:02
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Re: Trig Lookup Table
Originally Posted by michniewski View Post
I've seen the trig lookup table function posted by Kevin Watson (this one: http://kevin.org/frc/frc_trig.zip ). I'm just wondering if anybody has an idea on how to implement an inverse cosine function?
Thanks,
Michael Michniewski
I can't help with the inverse stuff but I did just cobble together a SIN/COS/TAN function lookup table in Java to show one of the students how it could be done. Remember, it's java, so you'll have to adjust the parameters and the data types as appropriate (signed, unsigned, etc).
 * Main.java
 * Created on February 16, 2007, 12:54 PM
 * To change this template, choose Tools | Template Manager
 * and open the template in the editor.
package triglookup;
 * Table Values provided from: http://www.industrialpress.com/en/tabid/63/default.aspx
 * @author purduePhotog
public class Main {
    //TRIGTAB is x1000 values for added precision.
    private static int[] TRIGTAB = {0,17,35,52,70,87,105,122,139,156,174,191,208,225,242,259,276,292,309,326,342,358,375,391,407,423,438,454,469,485,500,515,530,545,559,574,588,602,616,629,643,656,669,682,695,707,719,731,743,755,766,777,788,799,809,819,829,839,848,857,866,875,883,891,899,906,914,921,927,934,940,946,951,956,961,966,970,974,978,982,985,988,990,993,995,996,997,998,999,1000,1000};
    /** Creates a new instance of Main */
    public Main() {
     * @param args the command line arguments
    public static void main(String[] args) {
        // TODO code application logic here
        //Test the values of each function:
        //int n = -360;
        int n = 0;
        while (n <= 365) {
            System.err.println("Angle Test: " + n + "\tTAN: " + (double) TAN(n*100) / 1000);
            n = n + 5;
    //Expects ANG to be x100
    //public signed int SIN( signed long ANG, int SCALE) {
    public static int SIN(long ANG) {
       //Get us in the proper range for Sin to work.
        while (ANG > 36000) {
            ANG=ANG - 36000;
        while (ANG < 0) {
            ANG= ANG + 36000;
         //if we're from 0-90 (0-9000) then we simply return the lookup value
        if (ANG <= 9000 ) {
            return (TRIGTAB[(int)ANG/100]);
        } else if ((ANG > 9000) && (ANG <= 18000) ) {
            return (TRIGTAB[180 - (int)ANG/100]);
        } else if (( ANG > 18000) && (ANG <= 27000) ) {
            return (-1 * TRIGTAB[(int)ANG/100 - 180]);
        } else {
            return (-1 * TRIGTAB[360 - (int)ANG/100]);
    public static int COS(long ANG) {
        //Simply offset the SIN by 90 degrees phase
        return (SIN(9000 + ANG));
    public static int TAN(long ANG) {
        //Simply offset the SIN by 90 degrees phase for COS
        int cosResult = COS(ANG);
        int sinResult = SIN(ANG);
        if (cosResult == 0) {
            cosResult = 1;
        return ( sinResult * 1000 / cosResult );
Lookup Table Generator GUI teh_r4v3 Programming 6 15-02-2006 22:22
A VERY nice perl script for generating lookup tables. Validius Programming 11 31-03-2005 10:15
Large Lookup Tables Mr. Lim Programming 5 16-02-2004 21:30
Lookup table generation tool WillyC Programming 12 15-02-2004 21:01
Trig archiver 2001 4 23-06-2002 23:14
