Go to Post Safety captains be watchful. - Al Skierkiewicz [more]
Unread 25-01-2007, 18:32
Reaper40's Avatar
Reaper40 Reaper40 is offline
FRC #2061
Team Role: Webmaster
Reaper40 is an unknown quantity at this point
how do u wire double solonoid valve?
the double solonoid valve requires 24v and the spike can only take in 12V so i dont know what to do?
Unread 25-01-2007, 19:05
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: how do u wire double solonoid valve?
If I'm not mistaken doesn't the Solenoids get pluggend into one of the Digital / Analog inputs on the RC and then from the RC it goes to the Relay via a PWM Cable. It should be in the wiring schematic thats in the manual.
Edit: Ok so I was wrong on that one =) My bad!
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Chris_Elston's Avatar
Chris_Elston Chris_Elston is online now
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
You should change the coil to 12 VDC.
* You must remove the 24V coils from the solenoid valves and replace them with the grey 12V coils before installing them on your robot. This is done by removing the mounting screws, and switching the 24V coils for the 12V coils provided. More information about these valves is provided in the FIRST 2007 Pneumatics Manual posted on the FIRST website: http://www2.usfirst.org/2007comp/oth...s%20Manual.pdf
The SMC Pneumatics kits have been sent to your team’s Shipping Contact as entered in your TIMS record. The contents of the kits are listed below:
- QTY 1: Straight fitting, male, 5/32" tube, 1/8 NPT (PN KQ2H03-34S)
- QTY 1: Elbow fitting, 90, 5/32" tube, 1/8 NPT (PN KQ2L03-34S)
- QTY 5: Elbow fitting, 90, 1/4" tube (PN KQ2L07-34S)
- QTY 10: Straight fitting, 1/4" tube (PN KQH07-34S)
- QTY 10: Elbow fitting, 90, 1/4" tube (PN KQLO7-35S)
- QTY 5: Tee union, 1/4" tube (PN KQTO7-00)
- QTY 6: Flow control (PN NAS2201F-N01-07S)
- QTY 2: Sub base, 1/8” ports (PN SY3000-27-1T)
- *QTY 2: Double solenoid valve, 24VDC (PN SY3240)
- *QTY 1: Single solenoid valve, 24VDC (PN SY3140)
- *QTY 5: 12VDC replacement coils (PN SY114-6LOZ)
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 25-01-2007, 19:08
caraddicted101 caraddicted101 is offline
caraddicted101 has a spectacular aura aboutcaraddicted101 has a spectacular aura about
We took both positive wires and attached them to the positive and negative connections on the spike. The negative wires from the solonoid go to the negative part of the breaker panel. This way when you apply power the air goes one way, and when you reverse the power the air goes backward.
Unread 26-01-2007, 00:15
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Hi caraddicted101, Are you sure that's allowed? The wiring diagram shows both wires to a solenoid connected to a spike. Have you been through an inspection in previous years with it like that. I know, electrically its fine, just don't want to get stuck in inspection.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 31-01-2007, 12:57
FrontiEErsman FrontiEErsman is offline
FRC #2177
FrontiEErsman is an unknown quantity at this point
Are any other teams doing this / thinking about doing this? I believe someone else on my team is posting a question to the Q & A, so hopefully we can get an official ruling.
Unread 31-01-2007, 14:51
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Talking Re: how do u wire double solonoid valve?
We have used it every year that we used pneumatics. It is very useful.
The two wires go to the positive and negative ends of the spike. Single solenoids only provide a momentary switching which is useful for some applications but not for something such as a claw to grab ringers.
Just depends on the application.
The manual is very clear on how to wire.
Unread 31-01-2007, 16:20
dpc131's Avatar
dpc131 dpc131 is offline
AKA: Dan
FRC #0836 (Robobees)
dpc131 is a jewel in the roughdpc131 is a jewel in the roughdpc131 is a jewel in the rough
I was looking into this today to see if I could use 1 double action solenoid to control two different cylinders. In the past, we had wired them by connecting the negatives to ground. Then I found that the Spike User guide states it that way also. http://www.ifirobotics.com/docs/spik...uide-sep05.pdf
Unread 01-02-2007, 16:03
jcatt's Avatar
jcatt jcatt is offline
AKA: Jonathan Catt
FRC #1902 (Exploading Bacon and FRC #1251 TechTigers)
jcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of light
My team and i have a question. Can you connect both negative ends of the valve to the same crimp terminal to save space on the fuse pannel. The wire is so small of awg that "electricaly" it would be possibe, BUT is it allowed in the rules.
Jonathan Catt
Co-Owner and Systems Architect of ColorScene Inc.
Co-Sponsor of The RoboShow: Orlando
FRC 1251 Alumni
FRC 1902 Mentor
Unread 04-02-2007, 18:13
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
We also have played with wiring both parts of the valves to a single spike, although, you can't simply put the positive of one and negative of the other into one end of the spike and the negative of the first one and the positive of the second into the other end of the spike. Oddly, if you wire one end of the valve backwards (positive to the black wire and ground to the red) it still works as if you wired it correctly, which means no matter which way the spike is sending voltage, both sides are active and fighting against each other. At least that's how it works with the valve we're using. So, you either need to use some diodes to prevent backwards current, or my idea.
The idea I came up with, and I'm probably not the only one, is to wire the positive of one side of the valve to M+ of the spike and the positive of the other side to M-. Then wire the negatives of both ends of the valve to a separate wire, which goes straight to ground on the power distribution panel. You still need both a negative and a positive input to the spike, to keep it running. There must be a capacitor on the spike, because it will work once and only once without a negative input.
Anyway, is it legal to run both ends of a valve from one spike? I know rule R91 says, "Each motor, actuator, and compressor must be connected to one, and only one, speed controller or relay module." Does each end of the valve count as one acutator, or does the valve as a whole count as one? Secondly, is there anything wrong with my solution to running a valve from one spike?
void function(void)
  function();
Unread 16-02-2007, 14:48
Transformers Transformers is offline
FRC #2260 (Transformers)
Transformers is an unknown quantity at this point
Re: how do u wire double solenoid valve?
It is clear in the Spike manual linked above that what you said is a legal option for wiring the double solenoid. However, does anyone have any ideas on how to mount it onto the robot as that is also a regulation. also, does anyone know what the side threaded openings labeled "X" and "PE" are? I was thinking they might be vents for exaust but then what would the "EB" and "EA" openings be for? any suggestions? Thanks!
Yes, Spanky
Unread 16-02-2007, 15:24
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
"X" and "PE" are not used. "EA" and "EB" are the exhaust for the A and B ports. They do not need anything hooked up to them.
You can run a secondary regulator between the main regulator and the P port for both A and B regulation or in series after A or B for regulating the pressure on just one side of the cylinder. The flow regulators go on the cylinder and control flow out of the cylinder.
We also wire the red leads (one each) to the M+ and M- on the spike and run the blacks together to the negative part of the breaker panel.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 17-02-2007, 18:49
Mr. E Mr. E is offline
Its physics or stamp collecting
FRC #1883
Mr. E is an unknown quantity at this point
Infuriating....
I also needed to wire a double solenoid valve and used the above suggestionis.
I can only move the piston out, however.
Can any body help?
Unread 18-02-2007, 00:21
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Originally Posted by Mr. E View Post
Infuriating....
Can any body help?
If you connected the SMC dual coils as Andy (and the IFI doc) suggested above (M+ to red of one coil, M- to red of second coil, and both blacks to ground), THEN it is most likely a switch wiring, or programming problem. (See below for more details.)
The SMC dual coil is a "spool valve". It works by shifting a shuttle back and forth, so only one coil should be on at a time. Without vibration, it can "remember" the last state if both coils are off, but since the coils are rated for continuous energization, it's safer to simply keep one or the other on at any time. They only pull about an amp, so that's not too much drain.
HOWEVER, if both coils are turned on at the same time, the state is "indeterminant". It probably will stay in the previous state, but that's not guaranteed if one coil is slightly stronger than the other.
In your case, I'm guessing one or more of the following things happened, as these are the most common mistakes:
1) The valves aren't wired as stated above.
2) Someone forgot to change one of the two 24VDC coils to 12VDC on the valve
3) You have a program bug (I'm assuming you're mapping a switch or two)
-a) Your switches are not wired to the OI correctly
-b) You're reading the wrong switch on the OI
-c) The logic of mapping the switch to relay outputs is incorrect
-d) The wrong relay port(s) were written (you should be talking to a FOWARD and a REVERSE on a SINGLE relay port)
-e) You didn't turn off one coil when you turned the other on.
<edit>
4) There's a power problem with the Spike (no power, breaker failure, miswired Spike power leads, etc..)
5) Defective Spike - one side is dead (it happens!)
6) Damaged wiring, breaking the circuit
</edit>
For wiring, the most common wiring is to use one button bit on the OI. Connect a SPST (single pole, single throw) switch from that bit to ground. The software then looks at the switch state, and on the SAME relay either:
A) turn FWD on and REV off
OR ELSE
B) turn REV on and FWD off
This technique will energize one and only one coil, and keep that one on to insure it stays in that state until you select the other one.
<edit>
Another trick: Take a PWM cable, and make a "monitor block" in the middle. Separate the three wires in the middle of the cable from each other. Strip back a little insulation on each wire, enough to circle them around the screws on a three terminal barrier strip. This "extension cable" now allows you access to each of the three wires in a pwm cable for voltage testing, or an oscilloscope connection. This in turn allows you to quickly check both PWM/Victor signals, AND Spike relay signals to see if your problem is in the spike & valve (or Victor & Motor) hardware, or with OI switches & programming.
</edit>
I hope this helps you diagnose your problem. Please let us know what you found!
Note to other people --- The main difference in application between the single and the double coil valves are:
A) Single coil valves are normally used when you want the coil to SWITCH TO a SPECIFIC STATE when the power goes off.
B) Double coil valves are used when you want the coil to REMAIN in the LAST SET STATE when the power goes off.
Examples:
- Use a SINGLE coil valve on a pneumatic gripper's "pinch" axis, to guarantee it OPENS at the end of the round, to potentially score that last point while you were busy focusing on positioning your robot to score and forgot to open the gripper before that last panic second. (For this game, there are ways to insure it still holds onto a Keeper while awaiting autonomous startup, but I'll leave that as an exercise for you...)
- Use a DOUBLE coil valve on a ramp deployment cylinder, so it starts in the retracted state, but then STAYS OUT and not tries to fold up again when the power ends.
I hope this answers most of your questions.
- Keith McClary
Chief Engineer, Team 1502 "Technical Difficulties"
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Last edited by kmcclary : 18-02-2007 at 00:32. Reason: Added number (4) - (6) to diagnostic list, PWM cable trick
Unread 18-02-2007, 06:50
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Here is a link to more information on solenoid programming:
http://www.chiefdelphi.com/forums/sh...58&postcount=3
How does your team wire your Double Solenoids? Doug G Pneumatics 14 17-02-2005 23:25
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
SMC Double Action Valve. Josh Hambright Pneumatics 2 14-02-2003 10:24
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 29-01-2003 13:34
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
