Go to Post Don't rely on the field staff to get every ball to work with your machine....engineer a robot that makes the change not matter. - PayneTrain [more]
Unread 16-02-2007, 15:24
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: how do u wire double solenoid valve?
Originally Posted by Transformers View Post
It is clear in the Spike manual linked above that what you said is a legal option for wiring the double solenoid. However, does anyone have any ideas on how to mount it onto the robot as that is also a regulation. also, does anyone know what the side threaded openings labeled "X" and "PE" are? I was thinking they might be vents for exaust but then what would the "EB" and "EA" openings be for? any suggestions? Thanks!
"X" and "PE" are not used. "EA" and "EB" are the exhaust for the A and B ports. They do not need anything hooked up to them.
You can run a secondary regulator between the main regulator and the P port for both A and B regulation or in series after A or B for regulating the pressure on just one side of the cylinder. The flow regulators go on the cylinder and control flow out of the cylinder.
We also wire the red leads (one each) to the M+ and M- on the spike and run the blacks together to the negative part of the breaker panel.
Andy Brockway
Team 716, The Who'sCTEKS
How does your team wire your Double Solenoids? Doug G Pneumatics 14 17-02-2005 23:25
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
SMC Double Action Valve. Josh Hambright Pneumatics 2 14-02-2003 10:24
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 29-01-2003 13:34
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
