Go to Post Steampunk goggles are perfectly legal as forehead protectors. - Nuttyman54 [more]
Unread 16-02-2007, 15:27
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
Extra Battery
Is it legal to put an Energizer alkeline 9V on my arm to control custom circuitry which includes a servo? Technically, a servo is a mechanical unit that happens to have a motor inside. 9V power doesn't drive a motor, a PWM signal from the RC does. I don't see any complications with rule <R63>. Any thoughts?
Unread 16-02-2007, 15:29
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: Extra Battery
No other battery will be allowed.
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Re: Extra Battery
I believe all power sources must come from either the 12-volt or the backup battery. No fuel cells, additional batteries, solar panels or gerbils allowed.
Unread 16-02-2007, 15:33
IndySam's Avatar
Re: Extra Battery
wait one minute, what if you took a gerbil and hooked its wheel to a FP motor and used that as a generator?
Unread 16-02-2007, 15:38
Re: Extra Battery
<R59> says all 12V power must come from the lead-acid battery. I want 9V. <R53> says that all main power must come from the lead acid battery. I see custom circuitry power as secondary power. Can you give me a rule # to back-up your opinion?
Unread 16-02-2007, 15:43
Re: Extra Battery
<R53> prohibits any source of electrical energy besides the ES17-12 battery.
Unread 16-02-2007, 16:28
imax48236's Avatar
imax48236 imax48236 is offline
El Presidente
AKA: The Elf
FRC #1701 (Robocubs)
imax48236 will become famous soon enough
Send a message via AIM to imax48236
Re: Extra Battery
If your servo needs a +9 volt input, you may want to use a voltage regulator circuit which will lower the voltage from 12v to 9v. These are readily availible at RadioShack or your favorite overpriced electronics provider.
You might consider this:
http://www.radioshack.com/product/in...entPage=search
Hope this helped.
2007 Events:
Great Lakes Regional
Detroit Regional
<THIS SPACE FOR RENT, $3000 donation to Team 1701>
Unread 16-02-2007, 16:48
Re: Extra Battery
Before spending too much time figuring out if your extra battery is legal, also decide if your servo is legal. I would say it likely isn't. Please follow the 2007 Parts Use Flowchart on Page 19 of section 8 of the manual.
Unread 16-02-2007, 16:53
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Extra Battery
<R45> Items specifically permitted on 2007 FRC ROBOTS include:
• Additional HITEC HS-322HD Servos.
I believe only HITEC HS-322HD servos are legal.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 17-02-2007, 10:18
Re: Extra Battery
All of you are right, only the Hitech servos will be allowed, and all power on the robot must be derived from the ES 17-12 or the backup battery.
Sorry.
Unread 17-02-2007, 10:23
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Extra Battery
You can't put custom circuits in between the RC and any motors including servos. The servo must be directly connected to the PWM output on the RC. It already provides the correct voltage (7.2v) which comes from the backup battery.
Unread 17-02-2007, 16:09
RedHeadRobotics's Avatar
RedHeadRobotics RedHeadRobotics is offline
AKA: Brigid
FRC #2081 (Icarus)
RedHeadRobotics will become famous soon enoughRedHeadRobotics will become famous soon enough
Re: Extra Battery
The only power allowed is the power from the 12V battery or a 7.2 back up
Extra Battery Question 1337pcgamer General Forum 1 16-02-2006 19:58
buy extra backup battery MaxM Electrical 2 20-02-2004 18:11
extra parts great_one411 General Forum 3 17-02-2003 09:05
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Extra Seats archiver 2000 0 23-06-2002 22:51
