Go to Post "I need the adjustable hammer" "You mean that wren-" "No, it's a hammer" - Karibou [more]
Unread 16-02-2007, 20:42
imax48236's Avatar
imax48236 imax48236 is offline
El Presidente
AKA: The Elf
FRC #1701 (Robocubs)
imax48236 will become famous soon enough
Send a message via AIM to imax48236
Re: How do you make your compressorless system work, when all valves "bleed" air slow
The part number of the solenoid we used last year was made by Rexroth, with part # 5728400410
http://www.boschrexroth.com/pneumati...o= 5728400410
This was in last year's KOP, and is available for purchase this year. We have an extra if you want to trade/buy it.
Let me know if I can help any more.
2007 Events:
Great Lakes Regional
Detroit Regional
<THIS SPACE FOR RENT, $3000 donation to Team 1701>
Unread 16-02-2007, 21:16
WeldedHarlequin's Avatar
WeldedHarlequin WeldedHarlequin is offline
AKA: The Dread Pirate Zed
WeldedHarlequin is on a distinguished road
I am on the same team as Imax, and I'm the pneumatics captain.
I encountered this problem with the new SMC dual coil solenoids this year, and if you want to go that route I discovered that the problem significantly lessens (if not dissappears) when you remove the small gasket (there are two, one more flat, one smaller and more rounded). Having only the flatter gasket seemed to help.
I remember last year trying to use the Festo valve and having a lot of problems. I really just don't like it. I ended up going with the Rexroth, and not having any port problems.
My situation may be different, but I was using the Rexroth after the SMC (In Series, to slowly adjust the throw of the actuator). Here's what I did (a little bassackwards):
I had the SMC valve as usual, but EA and EB were ported into P on the Rexroth, and the A from the Rexroth was plugged (Actually achieved by running a piece of tube out of it into a plugged piece of brass T). That's the best way I could manage to control the exhaust.
Hope it helps, but if you have any more questions, just ask.
Have a Shpadoinkle Day!
Zip Ties are the Duct Tape for those to whom Duct Tape is forbidden...
"Rack & Roll" is like Tic-Tac-Toe gone horribly wrong...I love it!
Due to the graphic nature of this signature, it should not have been read by small children
Unread 16-02-2007, 21:19
Two years ago I also did a compressorless system with just one SMC valve, and honestly, it just came down to making sure there were absolutely no leaks, and I simply had to keep putting the valve back together to make sure all seals were tight. So it's possible. (I was using like a 1 1/2 inch throw, and got well into the 90 on two tanks).
Unread 17-02-2007, 21:01
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Originally Posted by WeldedHarlequin View Post
I am [our team's] pneumatics captain.
My situation may be different, but I was using the Rexroth after the SMC (In Series, to slowly adjust the throw of the actuator). Here's what I did (a little bassackwards): [used the Rexroth to plug the SMC's exhaust ports].
An excellent suggestion! I'll try a series valve string. (That's an easy test.) Who knows? It may at least SLOW the leak enough to work for this year.
Thanks for the offer, but that's the one I tried already (see above). It too slowly bleeds out its exhaust port. It was better than the Festo, but worse than the SMC dual coil. (It's also too late for mail swaps before ship, but we appreciate the thought!)
We're definitely overweight right now, so I *have* to solve this one so I can delete the compressor. (That's over four pounds!)
No more overnight shipping now (no mail on Monday), so unless someone else has some really slick trick we can try in the next two days with whatever we have on hand (or can get from a hardware store), I may have to resort to whipping up another "digital cork" servo-valve again.
Any other suggestions, anyone?
- Keith McClary
Chief Engineer, Team 1502 "Technical Difficulties"
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Recent movies that make you say..."wow" Greg Perkins Chit-Chat 18 03-11-2006 10:23
The nostalgia thread or "Do you remember?" or All things old. Elgin Clock Chit-Chat 128 06-11-2004 09:10
You know Chief Delphi has to many "You know ____ when...." threads when... Mike Ciance Chit-Chat 18 01-06-2004 15:10
Is the "sort by uploader" supposed to work in the "who am I" gallery? Greg Ross CD Forum Support 1 07-10-2002 07:05
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
