Go to Post Why not go the safer route? Use the robots to play Magic the Gathering. - kamocat [more]
Unread 16-02-2007, 21:00
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Vectors are shorting out!!!!!!!!!!!!! help!!!!
I know you say you cleaned everything out, but this still sounds distinctly like metal shavings. You should get some canned air (like the kind you use to clean computers), and spray inside them. You might even consider carefully removing the fans and examining the inside. The reason that you're experiencing the sparks only when you press the joysticks is because that when there is actually power running through the electronics you can see under the fan. There is definitely something physically wrong with your Victors, and I'll eat my hat if it isn't because there are still some particularly clingy metal bits in there. (One possibility is that the first time you made sparks, a metal bit may have fused itself between two electrical parts.)
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
BaneBot RS540 Motors Shorting Out: Jack Jones Kit & Additional Hardware 8 16-02-2007 11:04
Force vectors on a toothpick bridge Jeff_Rice Math and Science 2 21-10-2004 20:19
Division are out Matt_Kaplan1902 Championship Event 21 11-04-2004 21:07
Divisions are out!! Joel J Championship Event 55 06-04-2003 01:34
Belts are out Wheels are in? Kevin Ray General Forum 18 16-03-2003 18:46
