Go to Post Oh geez your using math. I never touched the stuff myself.:o - Koko Ed [more]
Unread 08-02-2007, 16:24
razzoc razzoc is offline
razzoc is an unknown quantity at this point
Using kevin's code for driving and camera tracking
We am using Kevin's 2.1 Camera Code: Bells and Whistles version and could use some help with getting the driving and the camera tracking to work. We are using MPLab rather than easyC since most of us are used to MPLab.
So, looking around the forum, I found that I have to uncomment Default_Routine() to get the driving to work. I realize that this raises other problems like pwm outputs interfering. I have the all the configuration settings to fine-tune the camera tracking, and it works in the CMUCam2 GUI. I was also able to get the driving to work individually with the code provided by IFI. Now the problem is to get them to work together.
I'd like to know what else I would have to modify to make the code work smoothly. I have read alot of threads by people who have problems getting the camera tracking to work, but I still couldn't find a clear answer. Btw, I am using the default pwm outputs (Camera: 01, 02) (Drive motors: 13, 15). From what I've read, pwm ports 01 and 02 interfere with default_routines() being uncommented so what exactly do I need to edit?
This is our first year in the FRC competition so any help would be appreciated.
Unread 08-02-2007, 17:17
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: Using kevin's code for driving and camera tracking
Here's what I have done so far. I have reassigned the
joystick #1 y-axis parameter (p1_y) to go directly
to pwm03 and pwm04. You can see that I have commented
out the calls to pwm01 and pwm02 since we are using
them also for the camera. Since pwm03 and pwm04
are the same value, the drive motors must be set up
so that they both drive in the same direction when
connected. I hope this helps. I haven't tried it yet
in our robot, but I think it should work.
/*---------- Analog Inputs (Joysticks) to PWM Outputs-----------------------
* This maps the joystick axes to specific PWM outputs.
//pwm01 = p1_y; /* Camera Pan Servo */
//pwm02 = p2_y; /* Camera Tilt Servo */
pwm03 = p1_y; /* was pwm03 = p3_y */
pwm04 = p1_y; /* was pmw04 = p4_y */
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 16-02-2007, 21:01
DotCom's Avatar
DotCom DotCom is offline
Productive Procrastinator
AKA: Christine
FRC #0692 (The Fembots)
DotCom is on a distinguished road
mm, yeah. We were wondering the same thing.
Team 692's Website
Unread 18-02-2007, 08:50
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
basically, comment out everything that changes pwm01 and pwm02 in process_data_from_uP (including defult routine) after your camera code
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Enabling Multiple Light Tracking Using Kevin's Code Mitch Programming 7 05-02-2007 06:17
eclipse & Kevin's camera code dasRatsel Programming 22 17-02-2006 12:43
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
