Go to Post After all, professional engineers know The Right Way To Do It (TM) and if we knew that we'd be deprived of the educational experience of screwing up. - phrontist [more]
Unread 16-02-2007, 19:44
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Speed controlling a relay..?!?!?one/????
Okay. We want to slow down the speed with which a spike relay drives a motor. We have tried programming in delays in the proccessing, and creating loops that would only let the relay activate after they had cycled for a while. We are trying to make it pulse on and off instead of constantly open or closed.
The problem with that is that the method that tells the relay to active makes it so that there will be a delay after we press the button so it takes a minute for the motor to go, but doesn't pulse the relay.
Has anyone successfully programed something that would pulse a relay in this fasion?
ps. We don't want to reduce the voltage to the motor because we want to retain power.
Unread 16-02-2007, 20:17
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Re: Speed controlling a relay..?!?!?one/????
Your post is a little confusing, but it sounds like you want to turn on a relay output immediately, then control the amount of time that it is on, and then enforce a minimum 'off' time.
How about something like this in your default_user() code...
#define TIMER_ON_VALUE 10;    // 26.3ms * 10 = 263ms
#define TIMER_OFF_VALUE 38;  // 26.3ms * 38 = 1 second
unsigned int TimerOn = 0;
unsigned int TimerOff = 0;
    if (TimerOn) {            // if on timer is running
      if (!(--TimerOn)) {    // decrement it, and if it just hit zero then...
         relay1_fwd = 0;     // turn off the output
        TimerOff = TIMER_OFF_VALUE;    //... and start the off delay timer
    if (TimerOff) {   // if off delay timer is running
      --TimerOff;     // decrement it
      // if user triggers motor on and neither timer is running
    if (p1_sw_trig && (!(TimerOff)) && (!(TimerOn))) {
      relay1_fwd = 1;                       // turn on the relay output
      TimerOn = TIMER_ON_VALUE;             // ... and start the 'on' timer
--Dave
Unread 16-02-2007, 20:53
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
If I read that correctly, it sounds like you're trying to make the Spike emulate a Victor with the pulsed power output. Why not just use a Victor? Pulsing the Spikes that rapidly is probably bad for them as well.
Matt Krass
Unread 17-02-2007, 00:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Concur with Matt. All you're doing here is making a very poor imitation of a speed controller. The speed controllers do exactly what you're trying to do, only faster, better, and more reliably. If you're trying to slow the motor down without losing power, you might just try mechanically gearing it down more. With your method, the motor will just sag and be backdriven during the off periods so you'll still be losing "power" just the same as with the speed controllers.
Unread 17-02-2007, 03:03
Ben Englert Ben Englert is offline
FRC #1072
Ben Englert has a spectacular aura aboutBen Englert has a spectacular aura aboutBen Englert has a spectacular aura about
Spikes are mechanical - that is, the current is controlled by moving parts. (Victors also are, internally, but they're tuned for high speed switching) You can probably wear one out pretty quickly by clicking it on and off too fast.
Before a match at SVR, 3/17/06
Tatsu: "Yo Englert, what's our autonomous mode?"
Me: "We'll find out, won't we."
Both: *maniacal laughter*
After the match's autonomous period ends:
Me: "Well, the basic control system still responds. That's always good."
Both: *further laughter*
Unread 17-02-2007, 03:26
Dave K.'s Avatar
Engineer/Mentor
FRC #0930
The specifications can be found here, and as long as the pulsing falls within the specifications, there is nothing inherently wrong with pulsing the relay on and off.
Since no expectations as to duration and repetition rate were provided, I chose somewhat reasonable values to use in my example. If a small motor were connected, the relay would probably survive at least couple days of competition. If a large motor were connected, then it would probably be good to have a box of spare relays on hand.
--Dave
Unread 17-02-2007, 16:58
Monochron's Avatar
Engineering Mentor
Thanks. I know that a victor would be better (and yes, that is what I want the result to emulate) however, we can't really do that at this stage. Our board is very compact and we don't have as much time as we would like. We really desire a programming solution.
If anyone has a solution to make a spike emulate a victor, though, that would be extremely helpful.
Unread 17-02-2007, 17:01
kitscuzz's Avatar
kitscuzz kitscuzz is offline
Not alotta posts
AKA: Kit
FRC #1389 (Worst Case Scenario)
kitscuzz will become famous soon enough
Originally Posted by http://www.ifirobotics.com/spike.shtml
Max Switching Rate 20 operations per second no load, 6 operation per minute for rated life at rated load.
Sure, it can switch 20 times a second, but only if you have NOTHING CONNECTED AND NO POWER.
At best you can turn it on and off 6 times per minute if you plan on attaching a motor to it. The spikes really just can't do speed controlling.
Unread 17-02-2007, 17:42
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Yeah, you are really much better off just using a Victor - they're not all that bigger than the spikes, you can probably squeeze them in somewhere.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 17-02-2007, 20:07
I have to disagree. 6 times per minute? 10 seconds between switches? That is patently untrue. I can walk over to the robot and toggle a switch a few times if you'd like proof.
Unread 17-02-2007, 20:49
MasterZahn's Avatar
MasterZahn MasterZahn is offline
Master of all things electrical!
FRC #1652 (LakeView Legends)
MasterZahn will become famous soon enough
Spike relays are meant to give a on signal, reverse signal, and a neutral signal. As someone said earlier, you should use a speed controler if variation is what you want.
MasterZahn
Unread 17-02-2007, 20:59
blaise blaise is offline
blaise is an unknown quantity at this point
Thumbs up Re: Speed controlling a relay..?!?!?one/????
I had this idea, but my team shot it down, I later learned that a relay is for full forward or full back or not at all, and speed controlers are used for motors. I hoped this helped.
Blaise
¡ Its electrical !
Unread 17-02-2007, 21:36
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
yeah, i see why you might want to use a spike. But frankly, unless you've used every PWM port, your team will basically need to deal. I'm not trying to be rude, but why even risk (i'm not sure of the electrical component, so i wont take a side) unnecessary damage to a SPIKE when a VICTOR is designed for exactly this purpose? They're not that much larger, and it sounds like this is exactly what you want.
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 17-02-2007, 21:43
Untrue. The only moving parts on a victor are the fan. They switch using MOSFETs (transistors).
Spikes do use mechanical parts. They do not like being switched quickly. However, nothing says you can't do so provided you are willing to live with the consequences. It is very possible that you will burn your Spike out.
Modify this code to fit it into your program.
spike_pwm_timer++;
if(spike_pwm_timer>=spike_pwm_max_value)
spike_pwm_timer=0;
spike=spike_pwm_timer<spike_pwm_ontime;
This will pulsewidth modulate your spike's output with a frequency of 40Hz/spike_pwm_max_value, with a duty cycle of spike_pwm_ontime/spike_pwm_max_value.
I did this one year for the last 8 rounds of nationals. It worked, sort of.
I think my values were
spike_pwm_max_value 32
spike_pwm_ontime 10
but your mileage may vary.
Again, you do run the risk of breaking things, so don't blame me for lighting your Spikes on fire.
Controlling motor speed WGRAY Programming 9 16-02-2009 22:50
Controlling team 803 Programming 10 21-02-2006 13:56
Edit- Can we connect more than one speed controller fan per breaker? DemonYawgmoth Rules/Strategy 7 03-02-2006 21:37
Controlling motors railerobotics Programming 6 17-01-2006 17:17
<R86> No more than one motor may be connected to each speed controller. Michael Hill Electrical 2 08-01-2006 02:00
