Go to Post Innovating for the sake of innovating, reinventing the wheel is probably the second biggest pitfall you can fall into when designing an FRC robot, if the wheel is already a very optimized, good solution. - Chris is me [more]
Unread 17-02-2007, 10:26
carbuff's Avatar
carbuff carbuff is offline
AKA: chad parsons
FRC #2228 (cougartech)
Team Role: Scout
carbuff has a spectacular aura aboutcarbuff has a spectacular aura aboutcarbuff has a spectacular aura about
backup battery
what's the amp-hour value of the backuo batteries?
how long do the back up batteroies usually last
Unread 19-02-2007, 08:28
Re: backup battery
The supplied battery is rated at 700maHr. Battery life varies from robot to robot depending on the usage of servos and camera. You may purchase increased capacity 7.2 volt packs or additional 700 maHr packs as you need. Check the robot rules and Tips and Guidelines for more info.
backup battery nirty Electrical 1 08-02-2006 14:40
Dump Backup Battery Kingofl337 Electrical 17 24-12-2005 13:44
EEPROM + Backup Battery Ryan Cumings Programming 4 28-02-2004 13:30
Weight of Backup Battery? sanddrag Control System 0 16-02-2004 20:58
Backup/EDUBot Battery Phil_Lutz Electrical 7 27-01-2004 22:56
