Go to Post That wheel appears to have been forged deep within the fires of Mount Awesome. - viking1902 [more]
Unread 17-02-2007, 12:25
Guru's Avatar
Guru Guru is offline
Executive Programmer
FRC #0912 (Iron Lyons)
Guru is an unknown quantity at this point
Extra pd ground block or circuit breaker?
We're using 4 CIMS, and 1 FP, so the power to them have to come from the maxi blocks, but the ground needs to come from the power distribution block, and there are only 4 black parts on the pd block. Are we allowed to use the ground on the mini breaker?
[EDIT] also, for the pd block, do the sides have to be assigned 'in' and 'out', or can you put 'out's on the 'in' side too?
\/\__Under Construction__/\/
Circuit Breaker Panel pacoliketaco Electrical 5 15-02-2006 15:49
circuit breaker board oljomo Inventor 4 08-03-2005 10:57
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
120 A circuit breaker tbmantia Electrical 2 05-02-2003 12:30
circuit breaker archiver 2001 2 23-06-2002 23:18
