Go to Post The battery will be mounted at the top, correct? There can be no other way. - Travis Hoffman [more]
Unread 17-02-2007, 13:00
hunter7 hunter7 is offline
AKA: Spence
FRC #2226 (Broncos)
hunter7 is an unknown quantity at this point
Send a message via MSN to hunter7
Re: Muffin Fans
I have been reading through the threads about the muffin fans, but I still can't figure out the best way to connect the large muffin fans. I f anybody can help, it would be appreciated.
Unread 19-02-2007, 07:25
Re: Muffin Fans
You may connect your fans to a 20 amp circuit breaker on one of the small fuse blocks. You didn't specify how many fans you plan to use, but two are acceptable on a 20 amp breaker. Were you planning on more?
Unread 19-02-2007, 11:43
AKA: Spence
FRC #2226 (Broncos)
Re: Muffin Fans
we will probably use two thanks for the help.
Muffin Fan Wiring Gusman1188 Electrical 3 16-02-2005 07:44
Victor Muffin Fans - Height Clearance? Mr. Lim Electrical 4 28-01-2005 15:32
Questions on Muffin Fans sanddrag Electrical 6 22-01-2005 10:57
Muffin Fans lizs702 Technical Discussion 1 21-02-2004 12:26
Muffin fans .. Mike Hendricks Electrical 4 19-02-2004 19:26
