Go to Post I wonder if Dave thinks the Chief Delphi kids are pimp... - Mike Ciance [more]
Unread 17-02-2007, 14:17
Armando's Avatar
Armando Armando is offline
...I'm hungry...
AKA: Naoki
FRC #2061
Armando is an unknown quantity at this point
motor wiring
our motors are driving opposite ways when we move the joystick forward. i need to know what to do.
"Is it the anime?..."
Unread 17-02-2007, 14:28
woody's Avatar
woody woody is offline
Too much metal for one hand! \m/
FRC #0033 (Killer Bees)
woody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to behold
Re: motor wiring
Just figure out which motor is driving in reverse, then swap its leads on your Victor motor (Red to M- and black to M+).
"The greatest of all mistakes is to do nothing because you can only do a little; do what you can." - Sir Sidney Smith
Unread 17-02-2007, 14:33
Armando's Avatar
...I'm hungry...
AKA: Naoki
FRC #2061
Re: motor wiring
ok, i'll try it now.
Unread 17-02-2007, 14:48
Armando's Avatar
...I'm hungry...
AKA: Naoki
FRC #2061
Re: motor wiring
my instructor doesn't want to do that...
Unread 17-02-2007, 15:50
woody's Avatar
Re: motor wiring
Why not? When you reverse the motors with the joystick, the Victor does the exact same thing internally. Thats just the way motors work; they are not polarity sensitive. This is the simplest solution and is perfectly safe.
Unread 17-02-2007, 16:21
Armando's Avatar
...I'm hungry...
AKA: Naoki
FRC #2061
Re: motor wiring
fyi our instructor is really stupid, all team members quit. All that is left is three ppl. i'm near quitting as well...
Unread 17-02-2007, 16:26
woody's Avatar
Re: motor wiring
I'm sure your instructor isnt stupid, and I'm sorry your teammates quit. Stick with it, and you'll have a great time and learn/teach plenty.
As far as the motors go, just explain that it won't hurt anything, its just changing the way the motor turns.
Unread 17-02-2007, 16:27
Armando's Avatar
...I'm hungry...
AKA: Naoki
FRC #2061
Re: motor wiring
you have no clue... even the other instructors quit!
Unread 17-02-2007, 16:29
woody's Avatar
Re: motor wiring
Well, I think the best thing to do is try to work through it and make the best of your situation. I wish you and what is left of your team the best of luck this season!
Unread 17-02-2007, 16:30
Armando's Avatar
...I'm hungry...
AKA: Naoki
FRC #2061
Re: motor wiring
thanks
Unread 17-02-2007, 17:17
imax48236's Avatar
imax48236 imax48236 is offline
El Presidente
AKA: The Elf
FRC #1701 (Robocubs)
imax48236 will become famous soon enough
Send a message via AIM to imax48236
Re: motor wiring
The inspection team at the regional event may not approve of reversing the polarity on the victors. They like + voltage to be red, and ground to be black.
2007 Events:
Great Lakes Regional
Detroit Regional
<THIS SPACE FOR RENT, $3000 donation to Team 1701>
Unread 17-02-2007, 17:31
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Re: motor wiring
M+ and M- are simply the outputs of the victor speed controllers. Motors can be given polarity in either direction, it just causes a reverse in the motor. This is a proper way to do it and GOOD PRACTICE. It allows your programmers to give equal control to the motors when they are running the opposite directions.
If you are interested, read up on motors:
http://www.howstuffworks.com/motor1.htm
This will explain that it is OK to reverse the polarity on a motor, and in fact the ONLY way to drive it in the other direction.
Another way to do it is through the programming, but switching your leads is the easiest and gives you the most even control.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 18-02-2007, 23:51
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: motor wiring
The programming of 1 motor in a forward direction(right side) to match the programming of another motor in the reverse direction(left side) is impossible to do with the FIRST supplied code. Autonomous maybe, but in telematic mode, that would mean one joystick forward and 1 in reverse just to drive straight. Your robot must be spinning in circles literally.
As far as the victors, they don't care what is attached to the M+,M- terminals. The V+,V- terminals are the ones to be concerned about. Yes, attach the wires reversed there and you will have learned a very expensive lesson and see some magic smoke.
Good luck this season. And as the losing NFL team fans always say: There is always next year. TIP: Find a another close by team to come in and mentor whats left. Maybe the instructor will come around with more experienced input.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 19-02-2007, 00:56
Ari Allyn-Feuer Ari Allyn-Feuer is offline
FRC #0753
Ari Allyn-Feuer is on a distinguished road
Re: motor wiring
I'm terribly sorry about the mentoring situation, but if they won't agree (which they should, no questions) there is an easy way around it which will solve the problem pretty well.
In the drive, where you're having code like
pwm03 = p1_y;
if that causes the motor to go backwards and you can't switch the leads (which is the best way to do it), you can effectively do the same thing by saying
pwm03 = 255 - p1_y;
which will map pulling the joystick back to the "forward" pwm ranges and vice versa. Neutral is still neutral of course.
This will be almost the same as switching it. Good luck with your mentor issues. Where are you and what regionals are you going to?
Ari.
Globe Motor Wiring almsfan21 Motors 3 08-02-2007 17:51
Wiring battery pack to motor via switch... Jeremiah Johnson Electrical 5 15-08-2006 18:50
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
Seat Motor Wiring zainali Electrical 3 15-02-2004 15:22
Wiring of Torque Motor Tom Fennell Motors 3 25-01-2002 20:26
