Go to Post FIRST is similar to real life in that nothing is perfect and you have to deal with the circumstances as they arise and make the best of it! - Sean_330 [more]
Unread 17-02-2007, 16:21
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
Backup Battery Charging Circuit
I have a question from the electrical team:
They built the custom circuit needed to charge the backup battery using the main 12V battery (found here). The output voltage to the RC is 8.8V instead of 7.2V. Is it still safe to connect the circuit to the RC? If not, what do you suggest we do? (we used the exact parts that are written in the diagram).
BTW, the output to the battery is 9V instead of 8.7, so we assume that's OK.
Thanks in advance,
"Steampunk" #1577 electrical team
Unread 17-02-2007, 22:20
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Backup Battery Charging Circuit
Check the other threads, there has been alot of discussion on this circuit. The condensed version is that the circuit works, but always charges (overcharges) at about 100mA. If we use the camera, we will use this circuit, but use a spike to switch it on and off.
Unread 19-02-2007, 08:13
David,
It sound as if you don't have a backup battery installed. Ths charger is desinged for the backup battery to be installed on the robot.
Unread 22-02-2007, 15:48
natis's Avatar
natis natis is offline
natalia
AKA: natalia soberanes
FRC #0987 (High Rollers)
natis has a spectacular aura aboutnatis has a spectacular aura aboutnatis has a spectacular aura about
Send a message via MSN to natis
where do you find the parts for the backup battery circuit?
Please reply soon. Thank You
Team 987 - The High Rollers - Las Vegas, Nevada
2002 -- Nationals Highest Rookie Seed
2003 -Xerox Creativity Award
2004 -LA Regional Semi-Finalists
2005 - Arizona Regional Finalists -- GM Industrial Design Award -- Las Vegas Regional Champions
2006 - Delphi "Driving Tommorow's Technology" Award -- Radio Shack Innovation in Control Award
2006 - Las Vegas Regional Champions -- Arizona Regional Finalists
2007 -Motorolar Quality Award
2007 - SVR semifinalist -- Las Vegas Regional Finalist
2007 --WORLD CHAMPS!!!
Unread 23-02-2007, 10:32
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Bateries are usually charged at a voltage slightly higher than their capacity. Our circut puts out something like that.
We found most of our parts at Radioshack and for the few we couldn't get we orded them from Digikey.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 23-02-2007, 10:43
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
Mouser.com has all the parts, although some might need to be cross referenced to equivalent part numbers. The diodes were the hardest to find, but Mouser does have them.
Unread 25-02-2007, 12:26
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Last year one of our engineers made a schematic to charge our back up battery. I am not sure if he knew that ifirobotics had one, but we built the circut and were going to use it to charge the battery for use with the camera, but when arriving at Trenton, we found the bot to be 20 pounds overweight, so the camera got the boot and along with it the need to charge the back up battery. We never got to test the circut, but I am pretty sure all of the parts are avalible from radio shack's parts cases.
Yes it is normal for a charger to outut at a higher volatage than the battery. Otherwise it would take a very long time for the battery to charge.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Unread 25-02-2007, 23:37
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Originally Posted by Rapt0r9 View Post
Last year one of our engineers made a schematic to charge our back up battery. I am not sure if he knew that ifirobotics had one, but we built the circut and were going to use it to charge the battery for use with the camera, ....
Better be careful with that. It is a violation of Rule <R56> to use any circuit other that the one specified by IFI to charge the back-up battery (last year it would have been a violation of 2006 Rule <R53>). As of Team Update #13, you can use alternate chargers to charge the battery off-board of the robot. But you only have one option for on-board charging.
-dave
Back-up battery charging circuit from IFI Don Wright Electrical 19 02-05-2006 20:41
571 Paragon Battery Charging Station Rick Technical Discussion 7 27-05-2004 17:14
Battery Charging Box MikeDubreuil Electrical 17 22-04-2004 21:38
charging backup battery Max Lobovsky Electrical 6 12-03-2004 10:24
Battery Charging - Warning! sanddrag Technical Discussion 11 21-01-2004 00:10
