Go to Post ... if there is no standard against which you determine success, then you can never fail. - dlavery [more]
Unread 17-02-2007, 17:01
kitscuzz's Avatar
kitscuzz kitscuzz is offline
Not alotta posts
AKA: Kit
FRC #1389 (Worst Case Scenario)
kitscuzz will become famous soon enough
Re: Speed controlling a relay..?!?!?one/????
Originally Posted by http://www.ifirobotics.com/spike.shtml
Max Switching Rate 20 operations per second no load, 6 operation per minute for rated life at rated load.
Sure, it can switch 20 times a second, but only if you have NOTHING CONNECTED AND NO POWER.
At best you can turn it on and off 6 times per minute if you plan on attaching a motor to it. The spikes really just can't do speed controlling.
Unread 17-02-2007, 17:42
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Yeah, you are really much better off just using a Victor - they're not all that bigger than the spikes, you can probably squeeze them in somewhere.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 17-02-2007, 20:07
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I have to disagree. 6 times per minute? 10 seconds between switches? That is patently untrue. I can walk over to the robot and toggle a switch a few times if you'd like proof.
Unread 17-02-2007, 20:49
MasterZahn's Avatar
MasterZahn MasterZahn is offline
Master of all things electrical!
FRC #1652 (LakeView Legends)
MasterZahn will become famous soon enough
Spike relays are meant to give a on signal, reverse signal, and a neutral signal. As someone said earlier, you should use a speed controler if variation is what you want.
MasterZahn
Unread 17-02-2007, 20:59
blaise blaise is offline
blaise is an unknown quantity at this point
Thumbs up Re: Speed controlling a relay..?!?!?one/????
I had this idea, but my team shot it down, I later learned that a relay is for full forward or full back or not at all, and speed controlers are used for motors. I hoped this helped.
Blaise
¡ Its electrical !
Unread 17-02-2007, 21:36
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
yeah, i see why you might want to use a spike. But frankly, unless you've used every PWM port, your team will basically need to deal. I'm not trying to be rude, but why even risk (i'm not sure of the electrical component, so i wont take a side) unnecessary damage to a SPIKE when a VICTOR is designed for exactly this purpose? They're not that much larger, and it sounds like this is exactly what you want.
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Controlling motor speed WGRAY Programming 9 16-02-2009 22:50
Controlling team 803 Programming 10 21-02-2006 13:56
Edit- Can we connect more than one speed controller fan per breaker? DemonYawgmoth Rules/Strategy 7 03-02-2006 21:37
Controlling motors railerobotics Programming 6 17-01-2006 17:17
<R86> No more than one motor may be connected to each speed controller. Michael Hill Electrical 2 08-01-2006 02:00
