Go to Post Team 233 cannot wait for the Florida Regional, but they have to because they have to build a robot or something first. . . - IbleedPink233 [more]
Unread 17-02-2007, 17:38
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Modified AndyMark Gearboxes
Hello,
We are having difficulties with our modified AndyMark gearboxes. Each wheel spins at a different speed. The wheel that spins first changes based on which direction we move the joystick.
Our Setup: 1 gearbox on each wheel
The gearbox has been cut to get rid of one half for decreased weight.
Anyone have any ideas why this could be happening?
Thanks!!
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
Unread 17-02-2007, 19:21
Re: Modified AndyMark Gearboxes
The Victor response is not symmetric around what the RC sends as 127. Are you negating (i.e., subtracting from 254) the pwm commands to one of the speed controllers? Try instead sending the same value to both, and swap the output wires to the motor to make it run in the direction you want.
Unread 17-02-2007, 23:03
Rob2713g's Avatar
Yes we are subtracting from 254 on 2 of the motors. I'll make sure that we check that tomorrow. THANKS!!
Could anything else also have an impact? Because the 2 motors that get the same values also spin at different speeds.
Unread 18-02-2007, 01:06
Many things can cause one motor to run faster or slower than another with the same voltage applied. Most of them fit in the category of mechanical load -- a fresh transmission that hasn't yet been broken in, a tight chain, an unlubricated set of gears, a binding shaft, or a wheel rubbing against something can all make a motor run slow.
Unread 18-02-2007, 16:03
Rob2713g's Avatar
Hello,
We switched the code and the wires. The robot now behaves as follows:
Front Left Wheel - FL
Front Right Wheel - FR
Back Left Wheel - BL
Back Right Wheel - BR
() - same time
The order that the wheels move in:
When moving forward - BR, FL, (BL FR)
When moving back - (BR BL FR), FL
When strafing/crabbing left - BR, FL, (FR, BL)
When strafing/crabbing right - (BR, FR, BL) FL
We have a mecanum setup identical as shown in this photo: http://www.chiefdelphi.com/media/photos/26582.
Any ideas or help is greatly appreciated.
pic: Outback system with modified Andy Mark gearboxes sam shawe Extra Discussion 5 21-02-2007 12:56
Problem with Modified Code Brigander Programming 14 31-01-2007 13:25
pic: A nikko RC car, modified Andy A. Extra Discussion 11 20-03-2005 11:59
can motors be modified ronnie_82 Motors 37 07-01-2003 08:09
can motors be modified ronnie_82 Rules/Strategy 2 18-12-2002 13:26
