Go to Post 1902...hmmmmm did it go oink oink boom when it blew up? - Rohith Surampudi [more]
Unread 17-02-2007, 13:32
D.Bear's Avatar
D.Bear D.Bear is offline
AKA: Dan Sinclair
FRC #0829 (Digital Goats)
D.Bear has a spectacular aura aboutD.Bear has a spectacular aura about
No camera data...
We hooked up the camera and we are using Kevin Watson's code, and when we try to run the program it shows "No camera data..."
Are there any suggestions that would help us???
James Penniston & Alex Rosenberg
Unread 17-02-2007, 18:53
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: No camera data...
There's a number things to check:
1) The backup battery is fully chared at 7.2 volts.
2) The TTL and power cables are attached to the camera and to the RC.
3) You have the servos in the corrent pwm connectors. (Their defined in tracking.h)
Right now our team is trying to fine tune the camera with our PID method before the robot ships tomorrow. :X
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 17-02-2007, 18:57
Read the CMUcam workbook on Kevin Watson's site. If you've followed the directions to the letter and it still doesn't work, see the Camera FAQ:
http://www.kevin.org/frc/camera/
Camera No Data Lakeeffect1674 Programming 5 04-02-2007 12:19
trasmitting data from a second camera iwdu15 Programming 1 02-02-2007 19:25
Question about default camera data table in easyC pro itsme Programming 1 16-01-2007 13:57
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
