Go to Post Do not under estimate the wood bots and brave little toasters! - hipsterjr [more]
Unread 17-02-2007, 19:33
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
pic: How we cool our compressor
eshteyn's Avatar
Re: pic: How we cool our compressor
This is not a joke this is really the configuration of our compressor.
Championship - Delphi "Driving Tomorrows Technology"
Unread 17-02-2007, 19:39
Xenozero Xenozero is offline
Xenozero
AKA: The inovator
FRC #1230 (Lehman Lionics)
Xenozero will become famous soon enough
Send a message via AIM to Xenozero
Wow, that looks "cool" lol. quick question, today after my team was doing some neat re-wiring our compressor would not go on, after rigorous checking with the multimeter, the pwm cable leading to the compressor practacly exploaded, and the black cable was the only one that melted like crazy, do you think it happend because of how hot the compressor gets, or of some other reason.
Unread 17-02-2007, 19:47
Originally Posted by Xenozero View Post
...the pwm cable leading to the compressor practacly exploaded, and the black cable was the only one that melted like crazy,...
That might happen if the connector got plugged in wrong on the RC. If you are off by a pin, the black can might be connected to +5 on one end and ground on the other.
Unread 17-02-2007, 19:48
eshteyn's Avatar
Thanks for the cool comment, lol. The first thing i would say is that the compressor should be hooked up with at least 18 guage wire, i used 14 to wire our compressor. Also electricity is the flow of electrons, which are negatively charged. They flow from positive to negative, and since the black wire is the negative thats why it melts. Also if you wire your compressor and it doesn't turn on but just melts the wire then you probably have a bad compressor or something has jammed in the motor causing the charge to build up and melt the wire. If you have more questions im me at etakto738
Unread 17-02-2007, 19:50
Xenozero
AKA: The inovator
cool, thanks everyone
Unread 17-02-2007, 21:19
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Wow, that looks "cool" lol. quick question, today after my team was doing some neat re-wiring our compressor would not go on, after rigorous checking with the multimeter, the pwm cable leading to the compressor practacly exploaded, and the black cable was the only one that melted like crazy, do you think it happened because of how hot the compressor gets, or of some other reason.
Last night we melted down a PWM cable. It had backed out of the connector on the Victor it was attached to. Then the ground (Black) pin slipped into the lug on the +12 volts feeding the Victor. POOF!!! +12 volts to ground made a LOT of smoke!!!
We were so glad that we had not fried the RC nor anything else for that matter.
Unread 17-02-2007, 21:29
Andrew Blair's Avatar
FRC #0306 (CRT)
It seems like those cables are magnetically attracted to the Victor power leads. Last year I did the same thing, and I seem to remember another team telling me they did it as well. Scary stuff.
Make sure all cables and power leads are hooked up correctly polarity wise, and when they are right, make sure they're tight! It'll save you alot of headaches later.
-Sir Francis Bacon
-Albert Einstein
Unread 17-02-2007, 22:06
woody's Avatar
woody woody is offline
Too much metal for one hand! \m/
FRC #0033 (Killer Bees)
woody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to behold
On the subject of PWM's coming loose, it is a good idea to put a blob of RTV silicone sealant (only a couple bucks at just about any hardware store) on all PWM connections. It holds them in place, but if you really need to get it off it can be peeled off with relative ease.
"The greatest of all mistakes is to do nothing because you can only do a little; do what you can." - Sir Sidney Smith
Unread 18-02-2007, 00:00
eshteyn's Avatar
We use hot glue, works perfectly
Unread 18-02-2007, 01:01
Alex Minot's Avatar
Alex Minot Alex Minot is offline
FRC #1676 (Pascack Pioneers)
Alex Minot will become famous soon enough
Send a message via AIM to Alex Minot
Lightbulb Re: pic: How we cool our compressor
to be honest with you....that is really not necessary. The compresssor is built to perform.....so it is inevitably going to get hot...but it is supposed to do that. We run our test board with the compressor and we push that little thing pretty hard, it gets so hot you cant touch the top but its fine. And the match is very short, only a few minutes, so the compressor will only be on a max time of the match time, which is pretty brief, but still very demanding of the compressor. If weight is an issue for you guys, i would consider removing that.
2005 Rookie All-Star NJ Regional
2006 Judge's Award NJ Regional
2006 Safety Credits Award NJ Regional
2006 Safety Credits Award Palmetto Regional
2006 Palmetto Regional Finalist
2007 NJ Regional Motorla Quality Award
2007 NJ Regional Johnson and Johnson Sportsmanship Award
2007 NJ Regional Best Website Award
www.team1676.com
Unread 18-02-2007, 02:28
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
I'm going to agree with that. Just seems like a waste.
On a side note (in the past) COTS fans have been considered motors and are illegal. I looked around the Q&A and didn't find anything, so you might be okay, but don't be surprised if you fail inspection at your event(s) and have to remove it.
If your compressor gets too hot to the point of where you need a heatsink after running it for 2 minutes (or less) then something is probably wrong with your compressor. Our pneumatics demonstration board has ran for several hours straight before when the programmers were working with it .. and the compressor got warm/semi hot to the touch, but nothing worth being concerned over, and nothing that could cause any burns or raise any safety concerns (although common sense is a different story)
JMHO
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 18-02-2007, 06:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
if the compressor is running in reverse, it will still work but not as well and it will get very hot very quickly. you might want to check that it is running the right way.
Unread 18-02-2007, 11:38
eshteyn's Avatar
It is running the correct way, I've checked this numerous times. Our compressor would get extremely hot after about 2 minutes because we would use it so much, we have lost 2 compressors on our 05 robot due to heat so this year were are not risking it, also the heat sink was lying around not doing anything, sow e put it to work, now out compressor runs cold no matter what
Unread 27-07-2007, 13:49
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Since I didn't want to start a new thread, I thought I would go off of this one since it seems to be pretty relevant to my question.
Can a compressor burn out? I know that all of ours will get very hot with extended use. I want to know because we are rebuilding our T-Shirt Shooter robot. We are going to use 3 compressors to reduce the stress on the compressors and to speed up the fill time. Back to my original question though, can a compressor get so hot that it ruins the gaskets inside the compressor?
Also as a side note for any other teams that look at this. I took apart the compressor yesterday just to check things out (this is our 2004 compressor and it is missing a bolt in the back and a bolt in the panel on the front. The front panel isn't air sealed at all, it's just a sound dampener. If you take the front panel off, you will see the piston and the motor output. Theoretically it shouldn't matter if you run the compressor in reverse, it should heat up in the same time. Also for the motor, there is no diode to control the flow of current. The "Thermal Protection" is just for the motor and not for the compressor itself. The "Thermal Protection" is a circuit breaker inside the compressor that trips if the current exceeds it's limit (I'm not sure what that limit is though)
I have a way to attach a thermistor to the top of the compressor to detect the temperature, but it wouldn't be legal in competition because I took out one of the top screws on the compressor and torqued it back down, so it would be modifying. The thermistor seems to be fairly accurate and shuts the compressor down at the same temperature as it's programmed to do. The only reason I asked if it can burn out is because this adds a lot of complexity to the system with programming, visual alerts to the OI, and then the custom circuitry (the circuitry is the easiest part though ). But please help me.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
how to expand our team???? Greg Powers Team Organization 7 23-08-2003 10:15
How do you cool your motors? Mercutio Motors 9 09-02-2003 00:21
How cool would it be??? archiver 2001 3 23-06-2002 22:36
How do i create those cool animations mnkysp6353 General Forum 4 29-09-2001 00:34
