Re: Problem with the Victors
My suggestion would be to use a smaller circuit breaker, like a 20 amp instead of a 30 amp, and using a bigger wire size. The rules have the bar minimum wire size, we always try to go one bigger. Good luck, I hope you figure out the problem.
| Problem with the program downloaded to the controller | itsme | Programming | 9 | 14-01-2007 12:12 |
| Problem with the 2005 controller | Guy_E | Programming | 10 | 18-12-2006 01:38 |
| Problem with the battery charger | Lightposter | Electrical | 4 | 19-01-2006 10:39 |
| Problem with Lowering the Bar | Kevin Kolodziej | General Forum | 14 | 12-01-2004 21:58 |
| The problem with scouting... | archiver | 2001 | 10 | 23-06-2002 23:49 |
