Go to Post Never, Never tell a prospective mentor what the actual job description is. You need to get them hooked first. :D - BJT [more]
Unread 17-02-2007, 19:26
DHarris's Avatar
DHarris DHarris is offline
Professional Procrastinator
AKA: Dana McDanaface
FRC #1845 (Panthera Robotica)
DHarris is on a distinguished road
Send a message via MSN to DHarris Send a message via Yahoo to DHarris
Problem with the Victors
We keep blowing Victors everytime we turn on our robot and use the joysticks. So far we have a box of Victors that have practically exploded when we attempt to drive. Is anyone else having this problem and does anyone know how we could possibly solve it?
Unread 17-02-2007, 19:45
Re: Problem with the Victors
I'm guessing you have your Victors connected improperly. Make absolutely sure that the + input is coming from a circuit breaker, the - input is going to a good negative "ground" point, and the M+ and M- pins are going to two sides of the same motor. Check for short circuits between the motor connections.
Unread 17-02-2007, 19:47
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
are there any metal shavings that may have fallen into the victors? this would cause them to short. i would suggest blowing them clean with compressed air and maybe even removing the fans for a more thorough cleaning. hopefully this is the problem and a simple solution.
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 17-02-2007, 19:53
DHarris's Avatar
Ah, they were connected improperly. It turns out that our mechanic re-connected them the wrong way after we got the robot back from Kimberly-Clark. Thanks.
Heh, we have about $600 worth of Victors that we probably can't use now though =/
Unread 17-02-2007, 19:54
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
I suggest u hook them up to a battery and a multi-meter and check, our victors did that once and they work absolutely fine now
Championship - Delphi "Driving Tomorrows Technology"
Unread 17-02-2007, 21:53
RedHeadRobotics's Avatar
RedHeadRobotics RedHeadRobotics is offline
AKA: Brigid
FRC #2081 (Icarus)
RedHeadRobotics will become famous soon enoughRedHeadRobotics will become famous soon enough
My suggestion would be to use a smaller circuit breaker, like a 20 amp instead of a 30 amp, and using a bigger wire size. The rules have the bar minimum wire size, we always try to go one bigger. Good luck, I hope you figure out the problem.
Unread 21-02-2007, 10:28
Dana,
You may be able to get them repaired by IFI for less than a replacement. Contact them to help you make a decision.
Problem with the program downloaded to the controller itsme Programming 9 14-01-2007 12:12
Problem with the 2005 controller Guy_E Programming 10 18-12-2006 01:38
Problem with the battery charger Lightposter Electrical 4 19-01-2006 10:39
Problem with Lowering the Bar Kevin Kolodziej General Forum 14 12-01-2004 21:58
The problem with scouting... archiver 2001 10 23-06-2002 23:49
