Go to Post ...FIRST was created to change that world for the better. To presume that FIRST is simply here for your enjoyment is to demote it to nothing more than an expensive game... - RogerR [more]
Unread 17-02-2007, 22:11
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Re: Help with process_Data_From_Local_IO()
Leave almost all code in Process_Data_from_Master_uP() (or Default_Routine()).
Process_Data_From_Local_IO() doesn't have updated values from the operator interface, so there is not much that can be done in it unless you know what you are doing.
problem with void Process_Data_From_Local_IO CmptrGk Programming 2 29-01-2005 17:14
help with shipping _GP_ General Forum 3 23-02-2004 16:26
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
help with inventor RogerR Inventor 2 11-10-2003 02:39
Help with Neumatics Tton Pneumatics 6 21-02-2003 20:42
