Go to Post The GDC is the Grinch because they just stole my Christmas! - scottmacdonald [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 17-02-2007, 22:23
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Re: How to connect limit switches with pwm cables?????!!!!!
if i remember correctly black to the ground on the limit switch (the prong that looks different from the other 2) and white (or signal) to either of the other prongs (depending on which you put it will be normally open or closed) i wired the signal to the prong closest to the ground one.
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
how to limit pwm on easyc GMAdan Programming 5 17-02-2007 23:41
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Extention Cables: 4 Shall Be the Limit Joe Johnson FIRST Tech Challenge 4 12-04-2005 23:33
Y-cables and switches archiver 2001 1 24-06-2002 01:02
