Go to Post I'm going through waves of excitment and panic all at the same time. - je2164 [more]
Unread 17-02-2007, 23:17
rohit's Avatar
rohit rohit is offline
Inventor Person
FRC #0617 (The Springers)
rohit has a spectacular aura aboutrohit has a spectacular aura about
Send a message via AIM to rohit
Need help with inventor-ing objects
Does anyone know how to inventor:
A mousetrap spring
A bungee cord
And I need help with putting gravity properties on an item.
And I need help with wiring (dont know how to do it in inventor)
And I need help with tubes (for pneumatics)
I'm the only person who does inventor in my team and this is my first year doing it, so im really confused...
Unread 17-02-2007, 23:53
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: Need help with inventor-ing objects
For a mousetrap spring and bungee cord, if you don't need them to be flexible, just use a coil with extrusions on each end for the mousetrap spring and a sweep for the bungee cord. To make them flexible, you'll have to use adaptivity, which will allow the size and shape of the parts to change along with changes in the assembly position. I can't really be any more specific without more information about the specific design of the mechanisms.
If you're talking about mass properties, you can set that in the document settings for the part, or, in each part file, go to Format>Styles Editor and set materials. Make sure the density value for each material is correct. To actually simulate gravity when parts are moving, the only place you can do that is in Dynamic Simulation. I don't know why you'd need that in any other context.
Wiring is done with Cable and Harness; Tubes with Tube & Pipe. You can learn each of those from the Routed Systems Getting Started manual, which comes with Inventor. It's located at a file path that looks something like this:
C:\Program Files\Autodesk\Inventor 11\PSS\AIP11_RoutedSys_GetStart.pdf
That's a 400 page manual, though, and the regular Inventor Help from the Help menu would be faster. Either way, you might consider saving wiring and tubing for last or skipping one of them, because it can take a long time to learn and model all of the wires and tubes.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 18-02-2007, 11:03
rohit's Avatar
Inventor Person
Thanks for the help. I will build the items for now and do the material properties after the robot is shipped.
need help assembling parts in inventor .. (was: help) jhallel Inventor 5 22-02-2007 01:46
help with the inventor[robot part missing] (ajuda no inventor[parte do robo faltando] team 2244 Inventor 6 12-02-2007 06:16
Inventor (need help starting) rohit Inventor 12 15-01-2007 19:33
I need help in inventor Nick R. Inventor 4 14-10-2003 08:04
Need help In Autodsek Inventor PhillyRobotics Inventor 8 27-12-2001 07:57
