Go to Post There's more elegant ways to play defense than beating on the other robot. - Bill Moore [more]
Unread 18-02-2007, 01:06
Re: Modified AndyMark Gearboxes
Many things can cause one motor to run faster or slower than another with the same voltage applied. Most of them fit in the category of mechanical load -- a fresh transmission that hasn't yet been broken in, a tight chain, an unlubricated set of gears, a binding shaft, or a wheel rubbing against something can all make a motor run slow.
Unread 18-02-2007, 16:03
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Hello,
We switched the code and the wires. The robot now behaves as follows:
Front Left Wheel - FL
Front Right Wheel - FR
Back Left Wheel - BL
Back Right Wheel - BR
() - same time
The order that the wheels move in:
When moving forward - BR, FL, (BL FR)
When moving back - (BR BL FR), FL
When strafing/crabbing left - BR, FL, (FR, BL)
When strafing/crabbing right - (BR, FR, BL) FL
We have a mecanum setup identical as shown in this photo: http://www.chiefdelphi.com/media/photos/26582.
Any ideas or help is greatly appreciated.
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
pic: Outback system with modified Andy Mark gearboxes sam shawe Extra Discussion 5 21-02-2007 12:56
Problem with Modified Code Brigander Programming 14 31-01-2007 13:25
pic: A nikko RC car, modified Andy A. Extra Discussion 11 20-03-2005 11:59
can motors be modified ronnie_82 Motors 37 07-01-2003 08:09
can motors be modified ronnie_82 Rules/Strategy 2 18-12-2002 13:26
