Go to Post Besides, all the FIRSTers that I know - are children at heart. - JaneYoung [more]
Unread 18-02-2007, 11:22
Asheron Asheron is offline
Asheron is an unknown quantity at this point
Would the following work!?!
or would it burn something out?
Using EasyC
I have the same setup on both sides of the robot; a pump that heads out/in to lower a ramp on either side (so its actually 2 pumps, 1 on each side of robot)
Could I use the same button to lower each and raise each by doing the following
OIToRelay (3,1,2,1) //jostick on port 3 trigger button forward to relay 2
OIToRelay (3,2,2,2) //joystick on port 3 thumb button reverse to relay 2
OIToRelay (3,1,3,1) //jostick on port 3 trigger button forward to relay 3
OIToRelay (3,2,3,2) //joystick on port 3 thumb button reverse to relay 3
Would it cause problems trying to use the same input to control relay outputs???
Unread 18-02-2007, 12:57
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Would the following work!?!
I may be a little confusing for the operator, but it should probably work.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 19-02-2007, 11:27
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
You can do multiple events with a single button push so you can have two spikes fire from one button.
So this will work very well.
Does anyone have information on the following teams? Michael Hill Scouting 4 15-03-2007 23:13
Following the Green Light with robot. Wompas Programming 0 26-01-2007 17:34
Designs that would never work... Cyberguy34000 Technical Discussion 60 09-01-2007 20:56
Wall Following Anyone? jaustin Programming 0 13-02-2006 00:42
Consider the following... archiver 2000 15 23-06-2002 22:40
