Go to Post You don't see teams plastering the arena with signs saying "Show your spirit!" or "Be creative in your robot design!" or "Be sure to be innovative in your control!" - Mr. Van [more]
Unread 17-02-2007, 14:42
Vashts6583's Avatar
Vashts6583 Vashts6583 is offline
The sleepless
AKA: Rob Metzger
FRC #0007 (Team 007)
Vashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to all
Send a message via ICQ to Vashts6583 Send a message via AIM to Vashts6583 Send a message via MSN to Vashts6583 Send a message via Yahoo to Vashts6583
Question Non-camera servos in Autonomous
Alo. I wish to have a servo move from 0 to 255 during autonomous mode, but I can't seem to get it to work at all. I've tried just hard-setting it to 255 and also moving it in increments (25 every loop), but neither method seems to work. Anyone have a solution?
2005: Software Assistant
2006: Software Head
2007: President/Driver/Software Head/Temporary Safety Captain
//2005: Chesapeake Regional - Finalist
Life is what you do outside of FIRST. No wonder it's so short.
Unread 17-02-2007, 19:01
Re: Non-camera servos in Autonomous
Servo power is supplied by the 7.2v backup battery. Do you have one installed?
Unread 17-02-2007, 19:46
Vashts6583's Avatar
The sleepless
AKA: Rob Metzger
Yes, we do. I'm just not sure how to run it software-wise.
Also, I tested the autonomous with the dashboard hooked up, and the PWM that I have the servo hooked up to actually DID move to 254, but the servo itself didn't budge at all, yet the servo works with the controls on the OI... I know that the autonomous works with motors....but not with servos.... >_<
2006: Software Head
Unread 18-02-2007, 00:36
If it's working in teleop mode but not in autonomous, I'm going to guess that you're using the camera code from Kevin Watson, and your servo is on pwm13, pwm14, pwm15, or pwm16. If I've guessed correctly, read on. If not, I don't know what to tell you.
Kevin included a very nice PWM driver with the camera code. However, he didn't replace all of the original calls to Generate_Pwms() with calls to the new PWM(). Make the change yourself near the end of the autonomous loop.
Unread 18-02-2007, 01:05
Vashts6583's Avatar
The sleepless
AKA: Rob Metzger
Actually, I already did make the change. However, it still didn't work (servo is on PWM 15).
Is moving a servo in autonomous even possible?
2006: Software Head
Unread 18-02-2007, 01:56
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Yes, it is definitely possible, with no fancy tricks required. It sounds like you've got some issues with using PWM 13-16.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 18-02-2007, 08:39
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
our camera is mounted on 11 and 12. We have absolutly no problems. Try using a different pwm port.
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 18-02-2007, 12:20
Vashts6583's Avatar
The sleepless
AKA: Rob Metzger
Alright, I'll give that a shot, and I'll post the results. Thanks
2006: Software Head
Unread 18-02-2007, 12:31
Vashts6583's Avatar
The sleepless
AKA: Rob Metzger
Thank you very much. I was using PWM 15, and as soon as I changed it to PWM 11 it worked just how it was supposed to.
Best of luck in the competition.
2006: Software Head
using servos with camera team877 Programming 2 01-02-2007 21:26
Camera servos too slow, help please Lablabla Programming 9 19-01-2007 11:59
Camera without servos kiettyyyy Programming 17 10-04-2006 21:45
servos and the camera incognito_NICK Programming 5 09-02-2005 00:00
Servos for the camera MV_Hirsch Programming 4 24-01-2005 16:35
