Re: FRC 48: Transmission Issue
It's probably your servo still. The amount of force that must be applied by the servo is great, and the servo simply doesn't have enough torque to shift the transmissions well with the gear ratio that you are using.
What happens when you shift when the motor speed is really low? From what you posted, I'm taking that the dog is sticky on the hex shaft and/or the servo isnt strong enough to shift. As the servos generally ARE strong enough to shift, you should probably take apart the dog/pin/hex assembly and file the corners of the dog and the slot for the pin that goes through the dog.
From my experience with dog shifters (Ive made 3 different designs), shift resistance has ALWAYS been due to friction in the dog assembly, never had anything to do with the gear speed, torque, etc. Just take the thing apart and file it and it should be fine. The servo should be plenty strong. |
| FRC Championships in the latest ROBOT magazine issue | skimoose | Chit-Chat | 12 | 07-08-2006 22:28 |
| **FIRST Email**/FRC Online Survey and FRC Team Forums | AmyPrib | FIRST E-Mail Blast Archive | 4 | 28-03-2006 13:07 |
| FRC 2005 Drivetrain and Transmission Parts on Autodesk Inventor 7 | KrazyRoadster | Inventor | 1 | 23-01-2005 20:29 |
| **FIRST EMAIL**/2005 FRC Game Design Communication to FRC Teams | Goobergunch | FIRST E-Mail Blast Archive | 1 | 06-01-2005 09:29 |
