Go to Post I owe it to the FIRST community and the awesome users of this site to keep working on this site and making it better. I will do so until someone from Chief Delphi pulls me away from it and tells me to stop. - Brandon Martus [more]
Unread 18-02-2007, 00:43
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Camera locks on but it still off
So we finally got our camera completely working, or so we thought. After getting the camera to lock onto the light really well and give us a distance to the light rather accurately we noticed that once the camera was locked on the pan servo was a few degrees off. This meant that when it was locked on from our home zone it appeared as though the camera was off by a foot or two. Is this related to something we did wrong in the code, or is that just how Kevin's bells and whistles code works? Thanks
Always remember to take your powered wheels off the ground when first testing code. Otherwise you'll end up with holes in the wall like us
Unread 18-02-2007, 01:06
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Camera locks on but it still off
This has been discussed a few times in the past. Here's one thread.
-Kevin
Kevin Watson
http://kevin.org
Unread 18-02-2007, 11:00
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Right now, when you square up the camera with our chassis, the actual field-of-view (which we found to be around 42* in the pan direction) is about 75% on the right side of our 'bot. We have adjusted the Pan Target pixel so that when tracking the camera unit points straight at the target, but now I am thinking that this isn't really desirable. Who cares where it points, you want the mx values on the center of the image sensor, right? Wouldn't that give you a better chance of not losing the light?
What about using pwm.h to adjust the PWM_CENTER value like so:
  1. Put the light directly in front of your camera/robot but far enough away from it, so that blob size is just a few pixels.
  2. The camera should aim to the left or right of it if the pan tracking pixel is at the center of the image sensor (default).
  3. When the terminal shows that pan error is close to zero pixels (try to get it within one) then record the pwm value being sent to the pan servo.
  4. Add (127 - pwmValueWithZeroPanError) * PWM_GAIN to PWM_CENTER for the pan PWM (or subtract--test which one helps).
Now a pan servo of 127 should mean the light is dead ahead (though the camera unit will be pointed away from it).
Is this better than changing the pan target pixel?
Thanks in advance,
Robinson Levin
[Note: I think that there is an underlying assumption in the adjust above that your previous PWM_CENTER value made a pwm output of 127 point the camera straight ahead, right?]
Unread 18-02-2007, 13:11
FRC #2429
Originally Posted by gnirts View Post
...Is this better than changing the pan target pixel?
Yes, if the optical offset moves the center tracking pixel that far, I wouldn't decrease your field of view by moving it. If you know what the angular offset is, just add or subtract it from your calculation and you should be good to go.
-Kevin
Kevin Watson
http://kevin.org
Not quite an animation, but still... Mazin 3D Animation and Competition 7 13-06-2006 22:25
Urgent help needed : Camera locks on to no apparent target! ?!?! Salik Syed Programming 11 06-03-2006 17:24
OI PWM Lights blink red but still works? SpeakerSilenced Programming 4 21-02-2005 10:44
Team 108 Finishes, but is still confuzed Specialagentjim 3D Animation and Competition 2 20-03-2002 19:33
What keeps you off a team but still with FIRST? Jessica Boucher General Forum 14 13-06-2001 21:37
