Go to Post Someone want to channel their inner Mark Leon and do the math? - Billfred [more]
Unread 18-02-2007, 15:33
rohit's Avatar
rohit rohit is offline
Inventor Person
FRC #0617 (The Springers)
rohit has a spectacular aura aboutrohit has a spectacular aura about
Send a message via AIM to rohit
Annoying constraint errors...
Does anyone else have trouble with constraints? I get constraint errors for no reason! It's so annoying. It says that the constraint isn't possible because of another constraint. and there is no other constraint in the entire assembly!! arrgh
Unread 18-02-2007, 16:59
Sean Marks's Avatar
Sean Marks Sean Marks is offline
AutoCAD User
AKA: Sean Marks
FRC #2016 (Mu Mu Psi)
Team Role: Student
Sean Marks is a jewel in the roughSean Marks is a jewel in the roughSean Marks is a jewel in the rough
Send a message via AIM to Sean Marks
Re: Annoying constraint errors...
that sometimes happens to us but rarely.
2008-NJ Semi-Finalist (Thanks 694 & 1279) / Chesapeake Winners (Thanks 1418 & 11) / Newton Finalists (Thanks 1574 & 141)
2007-NJ Rookie All-Star / Monty Madness Champs
Unread 18-02-2007, 17:42
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
well, if you mess up on a constraint or click on the wrong thing, you MUST go back and either edit the constraint or delete it. If you don't you will just constrain on top of other constraints which will "over constrain the sketch." If that is not the reason why you are getting errors please include more details or screen shot of the error in a reply so that myself and other people can be of more assistance.
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
Unread 18-02-2007, 17:47
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Originally Posted by rohit View Post
I get constraint errors for no reason! ...It says that the constraint isn't possible because of another constraint. and there is no other constraint in the entire assembly!
I have never seen this problem. Do you have the parts grounded (thumbtacks in browser)? Can you zip and post the iam and relevent ipts here
http://discussion.autodesk.com/forum.jspa?forumID=78
Unread 19-02-2007, 16:21
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Are any of the parts you placed assemblies? If you use sub-assemblies, you may get this error.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 20-02-2007, 12:34
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
One other item you may want to check for is a Flush constraint if the part was "Created" from existing geometry. I have had to delete the flush constraint many times on parts that were created in place.
Good Luck
Rope Constraint robbrad 3D Animation and Competition 0 16-02-2007 15:46
Hinge Constraint rohit Inventor 10 28-01-2007 15:17
Adaptative Spring - Driving constraint Daniel_H Inventor 2 03-11-2004 14:33
Gyros.. how annoying! randomperson Programming 3 12-02-2003 21:54
