Go to Post Lawrence North has air conditioning. If it didn't, more than just balls would be sticky. - Andy Baker [more]
Unread 17-02-2007, 22:46
Nothing551 Nothing551 is offline
FRC #0333
Nothing551 is an unknown quantity at this point
Very Wierd Error
I get this error when I try to build an altered camera code
C:\MCC18\h\stdarg.h:6:Error: syntax error
Does anybody know what this means and can anybody help?
Unread 17-02-2007, 22:48
FRC #0333
Re: Very Wierd Error
Never Mind sorry for the trouble
I found out the problem.
Unread 18-02-2007, 15:54
Gaj Gaj is offline
FRC #0246
Gaj is an unknown quantity at this point
I just encountered the error -- how did you solve it?
Thank you!
Unread 18-02-2007, 16:05
Orborde Orborde is offline
FRC #1747
Orborde has a spectacular aura aboutOrborde has a spectacular aura about
Send a message via AIM to Orborde
Such errors that seem to show up in standard header files are because C is kind of dumb. Look just before where the header file got #included in your code. It's often something like this:
int some_global = 7   // no semicolon!
#include <stdio.h>    // but the error will probably be shown as being from this file
Unread 18-02-2007, 18:03
Gaj Gaj is offline
FRC #0246
Yup, that was it, thank you very much!
(As it turns out, there was a rogue 'z' at the very top of the file)
wierd compiling error Joohoo Programming 1 08-02-2007 21:32
Wierd search behavior.... Salik Syed Programming 7 23-02-2006 13:12
Very wierd compiling problem! Max Brin Programming 6 08-02-2006 15:43
Wierd error (With edu bot ... Salik Syed Programming 4 09-03-2004 21:34
Wierd basic init Jeremy J Programming 5 06-02-2003 11:42
