Go to Post Well, it's officially that part of the offseason where we all lose our minds again. - Whippet [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 17-02-2007, 21:52
jesusescobar's Avatar
jesusescobar jesusescobar is offline
Jesus Escobar- PFTB-Programer
FRC #2066 (Pftb Of Doom)
jesusescobar is an unknown quantity at this point
Send a message via MSN to jesusescobar Send a message via Yahoo to jesusescobar
Exclamation How to connect limit switches with pwm cables?????!!!!!
Beware Of PFTB OF DOOM Robotics Team From EL Centro California Southwest Eagles!!!!!!!!!
http://pftbrobotics.com Our Site
Unread 17-02-2007, 22:00
Exclamation Re: How to connect limit switches with pwm cables?????!!!!!
Help AnyoNe!!!???
Unread 17-02-2007, 22:23
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
if i remember correctly black to the ground on the limit switch (the prong that looks different from the other 2) and white (or signal) to either of the other prongs (depending on which you put it will be normally open or closed) i wired the signal to the prong closest to the ground one.
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 18-02-2007, 16:29
Thumbs up Re: How to connect limit switches with pwm cables?????!!!!!
ok thanks
Unread 18-02-2007, 18:15
DonRotolo's Avatar
Back to humble
FRC #0832
Exactly correct: Wire the limit switch to close a contact between GROUND (black wire) and SIGNAL (White wire) on a DIGITAL Input. Depending on the mechanical configuration and whether the swicth is normally open (NO) or normally closed (NC) the digital imput will gr from 1 to 0 or 0 to 1 when the limit switch is actuated.
Remember, a limit switch is NOT a hard stop - overshooting the motion should not affect or damage the switch. If it will, your design is wrong.
Don
how to limit pwm on easyc GMAdan Programming 5 17-02-2007 23:41
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Extention Cables: 4 Shall Be the Limit Joe Johnson FIRST Tech Challenge 4 12-04-2005 23:33
Y-cables and switches archiver 2001 1 24-06-2002 01:02
