Go to Post What am I going to do with all of these torches and pitchforks now? - PayneTrain [more]
Unread 09-02-2007, 12:13
Calvin_1631's Avatar
Calvin_1631 Calvin_1631 is offline
AKA: Calvin
FRC #1631 (Cybernetic Cougars)
Team Role: Electrical
Calvin_1631 is an unknown quantity at this point
expandable wiring
Is there such a thing as expandable wiring? We have an expandable arm and we need to run some pneumatic 4mm tubing and wiring up to a motor on the end of our arm. Or arm extends about 3' and we don't know how to run our tubing and wiring up to the top of our arm. Any advice?
Unread 09-02-2007, 12:27
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: expandable wiring
You could coil your tubing using a heat gun and piece of pipe then ziptie the wiring to the tubing.
-Mike
Unread 09-02-2007, 12:30
Elgin Clock's Avatar
FRC #0237 (Black Magic)
<edit>
For the pneumatic portion, squirrel has a great idea below my post.
For the elctrical portion the following applies:
</edit>
The only effective way of dealing with this scenario that my team has used in the past is to have as much cable as you need to use to extend the full length, and then arrange it (very neatly) in some wire loom material or whatever so all the cable is covered from damage, and then use some sort of spring (surgical tubing or whatever) to hold it so it stays in a safe place when your arm is retracted to the minimum length.
Basically do anything that works, but also keeps the cables away from any pinch points, and use enough cable to not pull the cable out when you are fully extended.
I don't know of any cable that has "bungee" qualities as of yet.
And, this is not only coming from a team standpoint, but from someone who works in a cable assembly department at an Engineering firm.
We use so many cable types, it's unbelieveable, but as I said, nothing meets that magic "bungee" requirement that would be the best way to run cable.
Unread 09-02-2007, 12:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
-Mike
Interesting idea, coiled plastic air hoses are pretty common, why not make your own?
http://images.google.com/images?hl=e...=Search+Images
Unread 09-02-2007, 12:43
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Our Triple Play robot had a similar design problem. After much debate and trying a lot of different ideas, we ended up using a retractable lanyard mounted to the arm just behind where the extension began. We had a couple loops of wire & tubing attached to it together. The loops allowed us to get 3' of extension from an 18" lanyard. It worked very well for us. I could only find a couple of pictures of it, but hopefully they give you an idea of what we did.
ID:	5034  Click image for larger version
Unread 09-02-2007, 12:57
MrForbes's Avatar
AKA: Jim
Also consider using the igus "energy chain" from the KOP
Unread 09-02-2007, 14:01
You can use surgical tubing to fold the wire bundle as the arm retracts. A few short pieces work better than one long piece. It the tubing proves to be too strong, you can cut it length wise (using one half or one quarter the circumference). This is more commonly known as "accordian" because it looks and acts like an accordian when the arm retracts.
Unread 09-02-2007, 22:07
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
you can purchase coiled tube for pneumatics we are using it and it works great from mcmaster-carr
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 09-02-2007, 22:24
akshar's Avatar
akshar akshar is offline
FIRST=life
AKA: Fro
FRC #1568 (Mechanicatz)
akshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to all
Send a message via AIM to akshar
we just left from our workplace, and we discussed how we were going to run the wires and hoses to our manipulator, and we decided that the energy chain would work really well.
Think Bot, Dream Bot, Be Bot
Dream Big Reach High
2005: UTC Judges Award (We'll be Back Award)
2006: Boston Regional Winners with 121 and 233
2007: Boston Regional Finalists with 1626 and 121
Unread 09-02-2007, 22:25
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
We have the same problem, but we are going to go with the IGUS chain that came in the kit of parts. It does a great job if you mount it correctly and it has enough space to fit the pneumatic tubing.
Unread 10-02-2007, 00:50
DonRotolo's Avatar
Back to humble
FRC #0832
Look at your telephone cord....
Don
Unread 10-02-2007, 11:19
AKA: Calvin
yea, we will be going with coiling our tubing and wiring around something springy, maybe a slinky. But to bad they haven't developed some wireless wiring, or a tiny compressor that is only 1 inch square.
Unread 10-02-2007, 11:29
MrForbes's Avatar
AKA: Jim
Don
also look in the box of leftover pneumatic parts from last year, there is a red/blue coiled pneumatic hose assembly! this won't help rookie teams this year, though.
Unread 18-02-2007, 16:56
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
my team is thinking about using a tape measure like device where it retracts onto a spool when our arm restracts. Our arm reaches about 8 feet, so ours would need to be a bit more extensive. And we have 48 hours till ship.
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 18-02-2007, 17:05
Ari Allyn-Feuer Ari Allyn-Feuer is offline
FRC #0753
Ari Allyn-Feuer is on a distinguished road
The real easiest way to make a coiled pneumatic tube is to wrap it around a steel rod of the right diameter, nice and tight, and then submerge it in boiling water for 10 minutes or so. Comes out looking just like the stuff from McMaster. We do ours in the school chem lab every time we need coiled tubing.
Ari.
wiring? SPARKY1688 Electrical 4 31-01-2005 17:44
wiring Michael Leicht Inventor 2 21-01-2005 15:49
pneumatic wiring nick_champ_2 Electrical 3 23-02-2003 01:21
pneumatic wiring nick_champ_2 Electrical 0 17-02-2003 18:28
wiring. archiver 2001 1 24-06-2002 00:07
