Go to Post Including the Kinect in the kit a parts is actually an evil plan. The programers are going to spend all their time playing with the Kinect. In competition the robot is just to sit there because it will not have a program. :ahh: - FrankJ [more]
Unread 18-02-2007, 12:35
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
Contorl Solenoid direct from computer
Can we control a pneumatic solenoid direct from the robtic computer?
Unread 18-02-2007, 12:38
keenanmolner keenanmolner is offline
FRC #0753
keenanmolner is an unknown quantity at this point
Re: Contorl Solenoid direct from computer
I dont think so. I think that they have to go through a spike first but i'm not entirely sure about it. Hope this helps
Unread 18-02-2007, 12:44
idahorobot's Avatar
FRC #2130 (Alpha +)
I know things work through a spike and we have that working well but we are down to shaving ounces and if we can take two spikes out yea!
Unread 18-02-2007, 12:50
FRC #0753
if there are two solenoids that do the same thing, you could make a T connector to put them on one solenoid. this would allow you to take off one spike.
Unread 18-02-2007, 12:54
idahorobot's Avatar
FRC #2130 (Alpha +)
Tell me more please....A t connector?
Unread 18-02-2007, 12:55
No. The solenoids require about 100mA at 12 Volts. The RC puts out 5V, and I can't remember what the current limitation is.
Unread 18-02-2007, 16:58
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
FRC #0384 (Sparky 384)
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
actually you can control a double solenoid with ONE spike as opposed to, two. All you need is two rectifier Diodes, and the double solenoid (along with some crimps, wire cutters, blah, blah, blah)
the double solenoid has two 12volt coils on it (I hope).. so take a red from one side, and a black from the other side and crimp them together.. Then take the left over black and red, strip the wire, and solder the diodes to each wire. Make sure they are in opposite direction as well. On the diode,the side with the line on it should be soldered on the black wire coming from the double solenoid and another diode should have the red on the non-lined side.. (*note* - this is backwards because the current is coming from the other side) ... Then solder some wire onto the other side of the diodes, strip that wire, and crimp it together. Personaly I put the side with diodes on M+ and then non diode side on M-. You save weight, and also simplfy program by use of only one relay.
if this is Relay1 and you only want it on when the button is depressed then.... If (p1_sw_trig ==1) {
relay1_fwd = 1;
relay1_rev = 0;
else {
relay1_fwd = 0;
relay2_rev = 1;
so you save weight and code is simplified :-)
good luck
ahhh Division Finalists!!
Unread 18-02-2007, 17:08
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
relay1_fwd = 1;
relay1_rev = 0;
else {
relay1_fwd = 0;
relay2_rev = 1;
good luck
Very cool, and I hate to be a wet blanket, but I think that would be forbidden, since a custom circuit (which that technically is I think, though my memory of the wording of the rule is fuzzy) isn't allowed to directly control the outputs, that of which being a solenoid. Since it doesn't actually allow the solenoids to react without the RCs cooperation anyway at the same time I'd think it'd be legal, but I also have a feeling that the wiring rules may also forbid your modification, can somebody else clarify?
Matt Krass
Unread 18-02-2007, 21:14
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
relay1_fwd = 1;
relay1_rev = 0;
else {
relay1_fwd = 0;
relay2_rev = 1;
good luck
you dont even need the diodes, they have them built in, just hook one up backwards and your good to go.
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 18-02-2007, 21:52
Meezy the Mentor
AKA: Rameez
- Bochek
oh yea, come to think of it we only did for the coils w/o removable wire pieces. Good point
Unread 18-02-2007, 23:52
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
If you are going to actuate the solenoids at one time - you can just use one spike and one solenoid and T the pneumatics lines off of the solenoid.
That would minimize your weight and avoid custom curcuits.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Solenoid question from Israel Shomron1690 Rules/Strategy 2 21-01-2007 09:29
Pit News: Direct from the Source Mike o. General Forum 2 08-12-2005 13:05
Direct 7.2v power from the wall... Ferazel2001 Electrical 1 31-01-2004 17:49
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
Pit News; Direct from the Source Katie Reynolds General Forum 7 13-01-2003 22:28
