Go to Post OMG are you saying we are going to have a question mark game element next, that would be crazy - Greg Needel [more]
Unread 18-02-2007, 14:31
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
Exclamation Gear tooth sensor orientation
Quick question, does the orientation of the gear tooth sensors make a huge difference in results? I've seen that most gear tooths sensors will be mounted vertically (in the frame of reference to the ground), but since it's just a magnet being triggered by the gears, could it potentially be mounted horizontally? As long as it's ~1mm away from the gear teeth should it not still work? If anyone knows could they post quickly please, I need to know in about an hour or less.
Unread 18-02-2007, 17:07
flippo flippo is offline
FRC #1701
flippo is an unknown quantity at this point
Re: Gear tooth sensor orientation
We have gear tooth sensors mounted in a variety of orientations and they all work well. The important thing to remember is that you must have the active face of the sensor lined up with the gear as shown on page 5 of the datasheet: http://www.allegromicro.com/datafile/0642.pdf
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Gear Tooth Sensor? Raikon Kit & Additional Hardware 3 09-02-2007 16:40
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
