Go to Post Without mentors, you wouldn't even be participating in FIRST. Your team wouldn't exist, and FIRST as a program wouldn't exist. If it did, it'd just be another form of a science fair. - Cory [more]
Unread 15-02-2007, 13:15
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Re: HELP: analog input
Make sure you are calling the function
    Set_Number_of_Analog_Channels(SIXTEEN_ANALOG); /* DO NOT CHANGE! */
In User_Initialization(). Otherwise, I really don't know what to tell you. Make sure it's connected to the RC properly (wire ordering), there are no breaks in the PWM cable, that the wires are SECURELY (i.e. soldered) connected to the pot, and that you've tried it with all the analog inputs (well, 2-4 of them should probably suffice).
Good luck.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 15-02-2007, 13:23
Bharat Nain's Avatar
Okay, here is code from our robot this year. This is exactly how we have written it and it works.
We made variables on top of the file:
unsigned int BottomSonic = 0;
Then, inbetween Getdata and Putdata, we inserted these two lines:
Getdata(&rxdata);
TopSonic = Get_Analog_Value(rc_ana_in02);
printf("Top: %d\r\n", TopSonic);
Putdata(&txdata);
If you have it wired up correctly, then the code above will work.
Also, try it on a fresh piece of code with the absolute default code from IFI.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 15-02-2007, 13:38
FIRST JerseyKid's Avatar
FIRST JerseyKid FIRST JerseyKid is offline
Alumni
AKA: Erik Cokeley
FRC #0025 (Team Mercury)
FIRST JerseyKid is on a distinguished road
Send a message via AIM to FIRST JerseyKid Send a message via Yahoo to FIRST JerseyKid
Make sure your init functions are correct.
and call the get_analog_value()
Team 1089 alumni coach.
Unread 15-02-2007, 14:57
Originally Posted by Tottanka View Post
...and they connect to the analog inputs correctly...
You left out important details here. Please replace the word "correctly" with a description of the actual connection to the Robot Controller.
Unread 18-02-2007, 19:27
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I have been having the exact same issue. I tried IFI's ADC, Kevin Watson's integrated into my code, Kevin Watson's from his website(unmodified), and whatever EasyC uses.
They all read 0.
I have tried both the 2006 and 2007 controllers.
I have the pot connected so the 5v+/gnd each connect to one side of the pot, and the signal is connected to the middle connector on the pot.
If I short the gnd/sig pins the reading does NOT change.
I have used Kevin Watson's ADC without any issues before now. I have run it on VEX, EDU, and 2005 controllers.
I was at the Sussex mini-regional today and talked to 4-5 other programmers, and none of them had any ideas.
What am I missing?
Thanks,
Eric Haskins
Eric Haskins KC9JVH
FRC analog input RC filter values Gdeaver Control System 2 01-01-2006 22:03
Analog and digital input question Robby Control System 7 30-04-2005 20:07
Analog Input Trouble Matt Krass Programming 10 20-01-2005 21:09
Resistance to Analog Input Value. Josh Hambright Electrical 12 15-04-2003 16:12
DC Motor current to an Analog Input junkyarddawg Motors 43 04-04-2002 15:53
