Go to Post Prepare to be surprised, amazed, awed, and inspired. - Alan Anderson [more]
Unread 18-02-2007, 18:52
simeon1770 simeon1770 is offline
FRC #1770
simeon1770 is an unknown quantity at this point
SERIOUS COMPRESSOR PROBLEM
our compressor is only going up to 10 PSI, isnt it supposed to go up to 120? is there acertain way to program it in easyc Pro withthepressure switch? my compressor is in relay 1 and my pressures switch isin digital in/out 6
Unread 18-02-2007, 19:20
Gdeaver Gdeaver is online now
FRC #1640
Re: SERIOUS COMPRESSOR PROBLEM
You maybe running the compressor in reverse. Try Switching the leads.
Unread 18-02-2007, 19:48
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Does the compressor keep running, or does it shutoff?
Can you post your code?
In MPLab you would use:
realy1_fwd = !rc_dig_in06;
Eric Haskins KC9JVH
Unread 18-02-2007, 20:15
FRC #1770
well i use easyc pro, i got the compressor working, turns out i just had to turn the knob, but it still seems like its not sucking as much as it should be it can hardly even pick up the tube, but how do i get it to stop sucking so itwill let go of the tube, i have the side of the sleinoid valve thats going to the suction cup hooked up to a spike andi have the spike insideof digital output one, so howwould iprogram it
(IN EASYC PRO) to stop sucking?
Unread 18-02-2007, 20:25
robogeek753's Avatar
robogeek753 robogeek753 is offline
Droid Master
AKA: Bradley
FRC #0753 (The High Desert Droids)
robogeek753 is an unknown quantity at this point
Answer to question 1 (Why doesn't my suction cup suck very well?):
You may have the secondary regulator turned down to low, or if you used a flow control valve, it may not be in the fully open position. Set the secondary reg. to 32 psi for maximum effectives. Also, try using more than one suction cup (we did) and it might work better. Also check for leaks.
Answer to question 2 (How to stop the suction?):
Turn the spike off, just like you would with any other solenoid or motor (or the compressor for that matter), the suction should stop within several seconds.
GO 753
Unread 18-02-2007, 20:28
FRC #1770
ok,
1.how does the secondary regulator, and the flow control valve look? picture? also how do u set it to 32 psi?
2. how do i turn the spike off, even when thespike wasnt hooked up in a pwm slot it was still sucking, but notihave it in digital output 1
Unread 18-02-2007, 21:07
Ari Allyn-Feuer Ari Allyn-Feuer is offline
FRC #0753
Ari Allyn-Feuer is on a distinguished road
Originally Posted by simeon1770 View Post
ok,
The secondary regulator is a hardware device put in series with the solenoid in the line, before it. It has a physical knob you use to set the pressure. That should be in the Pneumatics manual.
You shouldn't have a solenoid valve hooked up to a digital I/O pin; it should be on a relay output. Then to turn on the vacuum cups you do something like
relay2_fwd=1;
relay2_rev=0;
And to torn them off you do something like
relay2_fwd = relay2_rev = 0;
I hope this helps,
Ari.
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Serious OI problems Arrowsmith Control System 8 10-03-2004 14:36
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Problem with compressor Nick R. Pneumatics 3 21-02-2003 10:51
