Go to Post "In PID, Integrals are like diamonds. They are forever!" - Sam390250 [more]
Unread 18-02-2007, 17:12
schroedinbug schroedinbug is offline
FRC #0443
schroedinbug is an unknown quantity at this point
Variadic functions with mcc18
Has anyone used variadic functions in their FRC code? I want to have a variadic debugging function, but the function appears to get ignored when called. I know the stdarg.h is available and the code compiles, bug I get zero output from the function call (it should do a varying number of printf's, including some for general newlines, which it does not do).
Any thoughts/opinions?
If you need to see code, I can probably get a small example of what I want posted.
Unread 18-02-2007, 17:14
jesusescobar's Avatar
jesusescobar jesusescobar is offline
Jesus Escobar- PFTB-Programer
FRC #2066 (Pftb Of Doom)
jesusescobar is an unknown quantity at this point
Send a message via MSN to jesusescobar Send a message via Yahoo to jesusescobar
Re: Variadic functions with mcc18
example would help
Beware Of PFTB OF DOOM Robotics Team From EL Centro California Southwest Eagles!!!!!!!!!
http://pftbrobotics.com Our Site
Unread 18-02-2007, 20:50
FRC #0443
First, add '#include <stdarg.h>' (without quotes at the top of the user_routines.c file).
void Debug_uchar(unsigned char count,...)
  va_list ap; /* the list of variables - needed for variadic functions */
  unsigned char i; /* counter variable - for loop will iterate through the arguements */
  if (num_of_prog_loops == DEBUG_LOOPS)
    va_start(ap, count); /* we need to initialize the arguement list */
    for (i = 0; i < count; i++)
      printf("%d: %d\n", i, va_arg(ap, unsigned char);
    printf("\n");
    /* num_of_prog_loops is reset at the bottom of ????? routine */
  va_end(ap);
num_of_prog_loops is a global variable being incremented, then set to 0 after a certain number of loops
Unread 18-02-2007, 23:26
Your printfs will compile but will fail to work if you don't #include <stdio.h>.
Unread 19-02-2007, 00:51
FRC #0443
This is in the user_routines.c file, which does have that defined. I'd expect the printf calls to work, since I've used them outside the function in the same source file. It seems that the program doesn't even go into the variadic function.
Known Bug With mcc18 and Wine 0.9.22 ScottWalls Programming 1 05-11-2006 15:03
Using MCC18 in a custom program EHaskins Programming 15 25-04-2006 23:35
Auton + Functions ten3brousone Programming 0 27-02-2005 20:11
Cordic functions... Zalumaskov Programming 1 13-02-2005 00:58
subs/functions maDGag Programming 2 16-02-2003 23:27
