Go to Post Part of Gracious Professionalism is the Professional bit. Doesn't matter if you're a volunteer or a staff member, a failure of this level in the real world would result in getting fired. - [more]
Unread 17-02-2007, 19:26
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Exclamation CANT GET THE CANERA CODE TO WORK!!!! plz HELP!!
can you help us anyone we cant get our camera code to work!
Unread 17-02-2007, 20:38
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: CANT GET THE CANERA CODE TO WORK!!!! plz HELP!!
I'm sorry to hear that.
Try this code snippet:
#define THE_PROBLEM
http://www.mikesorrenti.com/
Unread 18-02-2007, 22:51
Dr Nick Dr Nick is offline
FRC #0501 (The Powerknights!)
Dr Nick has a spectacular aura aboutDr Nick has a spectacular aura about
Send a message via AIM to Dr Nick
If all else fails: use the default code. If that fails, try above. If this advice is not helpful in the least, try specifying what the problem is, then we can better specify the solution.
Unread 18-02-2007, 23:07
AKA: Pat Miller
well thanks for that but at 9 am this morning we got it to work and its all good ONE MORE DAY!!!!!!!!
trying to get terminalc stuff to work in 2006 code Athena Programming 2 27-01-2007 21:28
Small edu code: PLZ HELP!!! Anime-niac_2.9 Programming 5 05-10-2006 20:15
Ultrasonic will not work with another Ultrasonic plz help Jackel148 Programming 10 10-05-2006 15:31
cant get to the Chat feature Elgin Clock CD Forum Support 4 28-01-2002 07:37
