Re: Variadic functions with mcc18
Your printfs will compile but will fail to work if you don't #include <stdio.h>.
This is in the user_routines.c file, which does have that defined. I'd expect the printf calls to work, since I've used them outside the function in the same source file. It seems that the program doesn't even go into the variadic function.
| Known Bug With mcc18 and Wine 0.9.22 | ScottWalls | Programming | 1 | 05-11-2006 15:03 |
| Using MCC18 in a custom program | EHaskins | Programming | 15 | 25-04-2006 23:35 |
| Auton + Functions | ten3brousone | Programming | 0 | 27-02-2005 20:11 |
| Cordic functions... | Zalumaskov | Programming | 1 | 13-02-2005 00:58 |
| subs/functions | maDGag | Programming | 2 | 16-02-2003 23:27 |
