Go to Post I guess we'll just have to resort back to our original plan of telepathy. - seg9585 [more]
Unread 19-02-2007, 04:22
ShadowFireGT ShadowFireGT is offline
FRC #2175
ShadowFireGT is an unknown quantity at this point
Re: OI LEDs on the 5v Aux
Awesome, thanks a lot. I guess I'll use the LED drivers to avoid messing up our joysticks. Programmers wouldn't be very happy with me.
Unread 19-02-2007, 13:10
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Also note that the LED driver ports will work well with Red, Yellow and Green LED's and do not require any additional series resistance, just wire the LED's as explained in the updated IFI documentation.
Blue and White LED's may or may not work because of the higher voltage required to light them, the resulting current provided by the operator interface may not be enough to light them brightly. If you do go down that path, look for higher efficiency LED's and consider the information in IFI's updated documentation along with some of the information in my past posts that may provide some additional insight.
--Dave
Unread 25-02-2007, 00:24
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Meh...
I'm using my 5V+ to power LEDs in 4 of my switches. I notice no 'lag' or unusability in any of my devices. I'm also currently using a couple of relays to control higher voltage devices (until I'm told otherwise that I can't).
I made a schematic in Capture, if anyone is interested, I can get a copy tomorrow and post it.
So my vote is that you can power a few LEDs, but not enough for decoration.
Jacob
Unread 25-02-2007, 08:05
Electrical Engineer
Rookie Year: 1995
Originally Posted by whytheheckme View Post
Meh...
Jacob
Jacob,
You have posted on a number of threads about this.
If the relays are touching the OI port and also are touching another voltage source, it is illegal and the inspectors will make you disconnect them before you are allowed to pass inspection.
Regards,
Mike
Mike Betts
As easy as 355/113...
Aux 1 & 2 WGRAY Programming 1 12-02-2007 14:59
controlling the leds hanan Programming 2 18-01-2007 22:05
Another question about LEDs on the OI. DemonYawgmoth Control System 2 18-02-2006 21:51
Fading LEDs using a PWM signal from the Edubot DanL Programming 22 30-03-2004 00:07
Aux Fuse 3 (Yaw Rate) Josh Hambright Electrical 0 18-02-2003 08:22
