Go to Post every year, Dean's speeches get better. in the process, he's also teaching people to be patient. - Winged Wonder [more]
Unread 19-02-2007, 06:59
3dude_2231's Avatar
3dude_2231 3dude_2231 is offline
no one messes with a Thingy =|
AKA: Menscher,Ran Menscher =]
FRC #2231 (Onyxtronix)
3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough
Send a message via MSN to 3dude_2231
Using different Camera Servos
hmm.. we in israel got some of the boxes all wet,
and our camera "jumps" when used,
I think it's a servo problem, and would like to test it,
at home, as an R/C airplanes pilot
I have SANWA standard servos, similiar to the HITECs we got in the kit.
am I allowed to use them instead?
thanks,
Ran.
Redefining the word "Rookie". (for 2 years now..)
Israeli Off Season Games: WINNERS!
check out this cool project I'm into..
Unread 19-02-2007, 07:02
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: Hi
From what I've heard, you can only use the servos in the KOP on the camera.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 19-02-2007, 08:20
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: Hi
Quote from the GDC at this topic:
As defined in Rule <R45> and <R46>, only HS-322HD servos may be used on the ROBOT.
Here are <R45> and <R46> just in case you don't know off the top of your head.
<R45>
Items specifically permitted on 2007 FRC ROBOTS include:
• Additional HITEC HS-322HD Servos.
<R46>
Items specifically PROHIBITED from use include:
• Electric motors different from, or in addition to, those in the Kit, with the exception of those specifically permitted by Rule <R45>.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 19-02-2007, 08:25
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Using different Camera Servos
For those of us in the USA the answer will be no. For teams like yours that are out of the USA FIRST will allow different parts sometimes if the original part is not easily available in your country. Check with Q&A.
Unread 19-02-2007, 08:32
3dude_2231's Avatar
thanks,
gonna check that with our local FIRST contact.
Unread 19-02-2007, 09:32
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
It might not be the servos!
Check out this thread: http://www.chiefdelphi.com/forums/sh...ight=crosstalk
Unread 19-02-2007, 14:01
3dude_2231's Avatar
I switched the servos as a test,
and it works better by far.
it still twiches while disabled,
but that's not disturbing.
the impotent thing is that it's not jumping like hell when used.
it's probably twiching because of it's value in Default_routine()
...it would be changed.
