Go to Post I guess it all just goes back to the fact that you need to finish your robot before it goes in the crate. - sanddrag [more]
Unread 19-02-2007, 07:59
RDD RDD is offline
RDD is an unknown quantity at this point
no camera data
what can be the reasonz for no camera data?
Unread 19-02-2007, 08:05
Re: no camera data
Any number of loose connections can prevent the code from receiving data from the camera. Look first at the TTL/RS-232 converter board, both ends of the camera data cable, both ends of the camera power cable, and the Robot Controller backup battery.
No camera data... D.Bear Programming 2 17-02-2007 18:57
Camera No Data Lakeeffect1674 Programming 5 04-02-2007 12:19
trasmitting data from a second camera iwdu15 Programming 1 02-02-2007 19:25
Question about default camera data table in easyC pro itsme Programming 1 16-01-2007 13:57
