Go to Post Guys, Can we agree that "we used it in the past" is not a response. Thanks. - Al Skierkiewicz [more]
Unread 17-02-2007, 12:01
fabbuki's Avatar
fabbuki fabbuki is offline
It's all about the math.
AKA: Nick Lee
FRC #0696
fabbuki is a jewel in the roughfabbuki is a jewel in the roughfabbuki is a jewel in the rough
Gray insulators, Din Rails HELP!
Dear Delphiers,
Do you know if we are required to put the gray insulator in between the black and red blocks on the Din Rails distribution system? The FIRST manual doesn't specify, except that the grays must go at the ends of the blocks (understandably). I see no reason for the gray in the middle, as the red and black blocks are already insulated from each other. It seems superfluous. Do you know if we are required to put the gray in the middle to pass inspection? If so, do you know of any loopholes to get around this (an official manual from the actual manufacturer, etc.)?
-Nick
Unread 17-02-2007, 12:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Gray insulators, Din Rails HELP!
wild guess as to why the gray blocks are there: mechanical protection. The grey blocks clamp onto the din rail with a screw, the red and black blocks just clip on, and can slide off if not retained by the gray blocks.
Unread 19-02-2007, 08:25
Nick,
There are two grey parts that were provided for this terminal block. The three blocks with the screws are the devices that tie the blocks to the rail. I recommend you use all three, one at each end and one in the middle, to keep the terminals snug. The grey spacers (thin grey parts) are meant for insulation between adjacent blocks. Although there should be no chance of electrical problems if you don't use the spacer, they will provide additional mechanical isolation betweent the adjacent blocks.
Purchasing DIN Rail Parts Bio Electrical 0 01-02-2007 18:48
DIN Rail? cdennisxlx2 Inventor 1 19-01-2007 07:51
Ruby on Rails ThomasP Website Design/Showcase 3 25-10-2006 03:11
Help Tom Gray graduate from MIT archiver 2001 6 24-06-2002 03:31
rails archiver 2000 1 24-06-2002 00:16
