Go to Post I hope you realize that by starting this thread you have earned yourself a permanent place at the "WOEWITWISTFT" ("What On Earth Was I Thinking When I Started THAT FIRST Trend?") table. It's members are few, but the conversation is the most honest and amusing in the entire place. ;) - Jessica Boucher [more]
Unread 18-02-2007, 17:50
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Smile Integrating Gear Tooth Sensor
Hello everyone,
I hope everyone has been working hard for past 6 weeks. Well actually I have a question regarding integration of gear tooth sensor. We so far have camera and gyro integrated. So basically our camera can track and lock on the light and than gyro can help position our robot facing the light. However, now we are facing the goal so we thought of using Gear Tooth Sensor to move our robot precisely to the goal. Based on the threads i tried to use Kevin's encoder code to run our gear tooth sensor but it doesn't work. Can anyone be please specific on how to get Gear Tooth Sensor programmed?
I took kevin's encoder.c and encoder.h and called encoder. h in user_routines_fast.c. I changed the interupt handler was installed but yet it didn't work. If someone can please give me some specific directions than it would be great Have fun everyone!
Jigar [1219]
Unread 19-02-2007, 08:48
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Re: Integrating Gear Tooth Sensor
Originally Posted by magical hands View Post
Hello everyone,
Jigar [1219]
http://www.chiefdelphi.com/forums/showthread.php?t=53483&highlight=user_routines_fas t_rkw
Try this thread. I don't know if it will work for us (as I'm going to have the software students test it at 10am) but it looks like it might.
Jason
Unread 19-02-2007, 20:29
AKA: Jason
FRC #3015
Hello everyone,
Jigar [1219]
I just wanted to say that the code I pointed you to worked- it fixed out encoder problem (At least for out GTS on IO/3). No phase data is possible, so it's not perfect, but....
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Gear Tooth Sensor Nathan Programming 4 12-01-2008 15:09
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
