Go to Post We're 3 pounds over. Drill until the hole saw is too hot to touch, then go find something else to cut off while you wait for it to cool down. - Richard Wallace [more]
View Poll Results: Have you had recurring problems with your radio and/or RC in the 2007 season?
Yes, but we fixed our problem. 7 8.14%
Yes, but we can't figure out what's going on. 50 58.14%
No, we haven't had problems. 29 33.72%
Voters: 86. You may not vote on this poll
Unread 13-02-2007, 23:13
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Radio/RC Problems for 2007 Season
Have you been having problems with your radio connection and/or your RC? Recently, I replied to this thread (http://www.chiefdelphi.com/forums/sh...d.php?t=53695), but never got an answer on what we should do.
My biggest concern is that, as far as I can tell (and maybe I've missed something here), as of Update 11, IFI has failed to communicate relevant information. I'm perfectly willing to acknowledge that our problem could just be our problem, but IFI should (some time ago) either have said, "Yeah that code works, let's call it the final version" or "Sorry that code doesn't work, we're working on something better." This has been a hindrance to our investigations since we cannot adequately isolate a variable.
My reasons for bringing this up are simple: A) to find out for my team a way to fix this problem and B) if this is more than just our problem, to let people know about it.
Thank you for your time,
Paul Dennis
Unread 13-02-2007, 23:40
wargy89 wargy89 is offline
wargy89 is an unknown quantity at this point
Re: Radio/RC Problems for 2007 Season
We also had radio problems but we quickly solved the problems with OUR radio. I dont know if it'll be the same thing with you. We found out that the backup battery was somehow interferring with the radio, Once we got a different and BIGGER battery problems solved. I'm not sure if this is why the radios are acting up but it worked for us. Hope this helps
Unread 14-02-2007, 00:28
JamesByrne's Avatar
JamesByrne JamesByrne is offline
FRC #0360 (The revelution)
JamesByrne is on a distinguished road
We are still having a problem, does anyone know a fix for this. since we are aproching shipping date fast.
Unread 16-02-2007, 15:53
aaeamdar's Avatar
Post-A-Holic
AKA: Paul Dennis
It seems that from our small sample around 40% of teams are having radio problems (no stats lectures please, I realize that's not really accurate). Can we get some solutions here? I'm really frustrated by IFI's lack of "pro-action". I know they do a lot for FIRST, but they seem to not be doing much in this situation.
Paul
Unread 16-02-2007, 16:09
Everyone who's had radio problems this year have called IFI about it, right?
Unread 16-02-2007, 18:14
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
We had the common problem of loss of signal. I followed the information on the IFI website FAQ forum then called for additional information.
We think ours is solved..... what we did was.....
1. Installed the updated code
2. Took the OI Radio and mounted it Vertical away from the controls.
3. Moved the RC radio to the highest point available on the robot away from motors and structure (antena is clear line of site at all times).
Once we did this all the problems went away.
OHHHHH I also turned off my hallway motion detector used to warn me of persons that are coming to my shop.
Mike Martus
Unread 19-02-2007, 00:56
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Team 930 has been using a bigger/higher capacity battery and continues to experience problems.
Perhaps a thread bump will elicit more respondants to make this poll more statisticly significant.
--Dave
Unread 19-02-2007, 08:05
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
We had the same problem with the radio losing signal when we were on the other end of the field. We changed the position of the radio on the robot and changed the cable just in case. It has not given us any problems since that move. It was lying flat beside of the backup battery and we moved it to the arm support and protected it with a cover.
Unread 19-02-2007, 08:51
David Fort David Fort is offline
FRC #1001
David Fort is on a distinguished road
Count us as having a lot of mysterious radio disconnect problems this year.
Team 1001.
In some cases we have been able to find something to blame it on (like having some other team on the same channel, or low batteries, etc.), but even when all those issues are resolved we are driving merrily along, the radio link fails, robot stops, toroid deposits on ground. sigh.
Unread 19-02-2007, 09:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I guess that is an unexpected benefit of having the claw in the closed position when power is off? we set it up that way for autonomous
Last night we had the robot take off pretty fast, out of control....on pretty much our only attempt to use the new radio. Finding a place to put the radio upright on the robot, away from metal, and always in LOS of the OI radio, is quite a challenge! but seems to be unnecessary when using the 2006 radio.
Unread 19-02-2007, 10:46
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
As posted in the previous thread (now bumped off the front page), our team had the same radio issues others have experienced. We sent the radios back to IFI, they reported nothing major wrong with them, but since getting them back we have had no further problems with cutouts. Last night/early this morning we drove the robot around full tilt, all mechanisms operating, and did not experience the same problems we had originally.
IFI is only capable of "pro-action" if you report problems to them. Let's face it, people post to a forum only if they're are having trouble, not if when they figure out the problem and everything is ok. Unless you call them and officially let them know something is wrong with your equipment, I would not expect them to continually refresh CD and write down the team #'s for everyone who has had a problem.
Unread 19-02-2007, 18:01
aaeamdar's Avatar
Post-A-Holic
AKA: Paul Dennis
True, but they certainly knew there was an issue with the code for the cut-off. They released a new version of the Robot Controller Master Code. Part of my point is that this should either be declared working and no longer in beta, or they should have (by now a long time ago) released a new version.
Paul
Unread 20-02-2007, 02:01
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
This slightly bothersome radio issue has now almost cost us our arm/tube interface. We jammed a denso and keyang against hard stops. I'm suprised we didn't strip out the worms in them. When controlling the arm with 2 potentiometers for our 2 articulations the thing just suddenly took off like a rocket, not listening to disable, and after some very scary noises, finally listened.
v14 master code,fully charged backup,
Unread 20-02-2007, 09:48
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
What do you mean by bigger/higher capacity battery? Aren't you required to use the ones to spec in the manual? (and which battery--12v or backup?)
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 20-02-2007, 10:39
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
1501 had alot of problems last night. We've done everything we are suppose to do as Mike M said above. We are going to make another call to IFI today but I am not sure what good that will do. We've got ours mounted on the PVC flag pole away from metal etc..
What fixed our problem was swapping to the 2006 modems. The rest of our practice went flawless. No radio drops, no uncontrolled ramming...
I can't even imagine what that is going to do with teams that have PID installed...with the error accumulating could be asking for crash em up bash em up and it won't be your drivers fault...
If nothing else, we will sit and look pretty in the spirit of FIRST.
disappointed in Indiana...Chris Elston Team 1501
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Volunteer staffing for the 2007 FIRST Regional season Andy Baker Regional Competitions 40 07-12-2006 15:40
Radio problems Charley Control System 11 15-02-2005 09:44
Radio Problems KWalsh Programming 3 24-02-2004 17:25
Shipping Problems for the 2003 Season Amanda Morrison General Forum 14 07-04-2003 15:37
Radio problems -- not archiver 2000 1 23-06-2002 22:23
